Results 1 to 10 of 16
Thread: leccy rear windows not working!!
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default leccy rear windows not working!!
    hey guys fitted the rear leccy windows and visited a member from here who said he could activate.....................but he could operate them from the tech2 but they won't work from the switches..............have i missed something
    thanks Andy
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Can only be something to do with the switches or its connections themselves,
    as the circuit between the window motors and the door control module and REC (rear electrical centre) must be okay for the windows to work from the tech 2 unit.
    Could be something as daft as a missed earth wire on the switch.
    Jun 2009
    bradford
    thanks.............so faulty switches?one maybe but not two I would have thought, wouldn't know how to check them!!,the switches are iluminated so surely they have power?
    Dunstable
    Just because they illuminate doesn't mean to say they will make a contact when pressed Have you tried cleaning the contacts inside the switch? Could be something simple like that. There's a thread on here about cleaning the switch contacts for people who's windows aren't working properly http://www.vectra-c.com/forum/showth...witch+contacts
    Jun 2009
    bradford
    Quote Originally Posted by Ademusic View Post
    thanks bud
    milton keynes
    can you not lift/lower them from the drivers switch? or do you still have your old switch with out the facility to operate the rear electric windows
    Jun 2009
    bradford
    Quote Originally Posted by kman247 View Post
    Hi Kaman - I have the old switch!!.......looking @ the how too on here and the activation process, I wreckon there is a good ten mins to programme, the lad who had a go was @ it 5 mins max, not convinced to be honest
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    my rear leccy windows dont work either.........................
    i have to wind them up....................................
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    The obvious thoughts are, whether ALL the necessary modules have been programmed to recognise that the electric windows are PRESENT.
    Other than this, check that all wire connections are clean and securely fitted.
    Then there are the fuses in the rear electrical centre.
    Strange question, but is there maybe a wire link within the correct front switches that is not present in the two door switch.
    (As I am sure there is probably a switch that isolates the rear windows, so that kids can't mess with the rear window switches.)
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Robsey View Post
    I think you might have it there, yes there is a switch to block the rear switches on the drivers panel.
  1. leccy windows don't open on unlocking
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2011, 19:00
  2. Rear leccy window conversion
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2010, 18:40
  3. Help installing my Rear Leccy Windows!
    By mathewjcooper in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2009, 07:50
  4. leccy rear switches
    By andy.l in forum Parts for sale
    Last Post: 8th July 2007, 00:34
  5. Rear Leccy Windows
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2005, 01:50
leccy windows
