Results 1 to 10 of 18
Thread: No Power
    sidcup kent
    Default No Power
    Hi peeps, Lost all power on my vectra 1.9 cdti 150 turbo doesn't even kick in and really dangerous pulling out of side turnings and off round abouts that slow
    had a look and looks as if that rod that is connected to the flaps on the inlet manafold has completely detached it self, and there is a layer of soot all over the engine when revving fumes are coming out of one of the holes where the flaps are.
    So a freind of mine today managed to get the rod back on (but quite loose) and cleaned all the Gunk out of the erg valve and has improved the power a little but still very sluggish and not running right would a new inlet manafold sort this out
    I'd appreciate any help and advise on this one
    many thx
    jim
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    With what you have described you need a new inlet manifold (and related parts), EGR etc - the job can be done between about £700 - £1200 dependant on where you go - with the fumes coming out of the swirls, there is no other option I'm afraid.
    Regular Member bunsen1's Avatar
    suffolk
    i just got the manifold with gasket £166.60 and actuator with connecting arm £95 from ebay
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    That's good, just need to get it fitted now! Good luck!
    sidcup kent
    Smile
    niceone people thx for reply and advise, i've just been qouted 194 squid for new inlet manafold and 170 for the fitting of it this sounds ok, but didn't realise untill coming back on here this morning that i'll need an actuator with connecting arm, you would have thought it would have come with it wouldn't you, won't most places tell you what you need when replacing this inlet manafold??
    and do I need a new ERG valve aswell?? How do i know if mine is knackerd??
    thx again peeps
    atb jim
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    There are many inlet manifolds complete on ebay with the rod and actuator and they are fetching about £150-£200 +P+P (some have been brand new over the past few weeks).
    After the trouble I had with my EGR Valve, I would recommend nothing other than a Brand New one (about £100.00 from vx).
    Take the whole lot to a local garage and if they are competent enough they should be able to fit the entire thing in a couple of hundred quid.
    Good luck!
    suffolk
    so you got quoted 179 for fitting of just the manifold? where from, big garage or a little one near you?
    suffolk
    sidcup kent
    Exclamation update time
    garage has rang me and told me job is a little more involved than they originally thought
    Hence the price went up to £578 inc vat which still aint bad Imo
    its a small Mot test centre near me in se13 london
    I just hope they're competant understand about having to reset everything as you say bunsen
    suffolk
    hope it goes ok for you mate, if your buying the actuator from somewhere make sure you ask if the arm is included as some places dont , vx sell it separately
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
