Thread: Power Steering Leak
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Default Power Steering Leak
    My 1.8VVT SRi is leaking fluid this evening. In the last week or so there has been a knocking noise coming from the front of the car occasionally at low speeds whether in gear or just coasting in neutral like down a hill in a traffic jam. Not sure if its related but this evening it got worse on the journey home.
    Pulled up on the drive and put the steering on full lock (Right hand down) and could see fluid dripping from the rear of the engine bay. The fluid was cold and clear but oily in texture.
    Moved the car, switched the engine off and the leak stopped. Found the p/s resevoir at the back of the engine, its a white bottle with a black cap and unscrewed the cap and found the dipstick dry apart from a little residue but it was the same fluid as i found on the drive.
    Anyway it appears to be one of the p/s pipes broke or cracked or loose below the resevoir. Has anyone had a similar instance of this occuring? And what is the fluid spec for the p/steering? Its certainly not ATF pink type.
    Could it infact be something more serious than a duff pipe?
    No EPS warning light on display so hopefully I haven't done more serious damage by running the sytem dry.
    Regular Member Jezzy's Avatar
    S.E
    I thought the power steering fluid bottle was under the driver's side wheel arch...?
    Co. Durham
    Engine : 1.8VVTi
    Mine's an 06 registered 1.8VVT SRi and its definately at the back of the engine.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    new petrol engined models are now driven by the ribbed V-Belt ,make sure pump doe'snt run dry at all or you are about to use your wallet.trhe fluid is the same as vx supply for the EHPS system.
    Co. Durham
    Engine : 1.8VVTi
    Bit red faced here.
    Turns out it was water from the air con system, although I'm wasn't convinced until the car came back from the garage and was given a clean bill of health. The driveway at home was totally clear as well! No oily residue.
    However, there is a creak / knock at the front which only appears intermittently and only at very low speeds - like less than 20mph and it does happen when I apply the brakes sometimes . The garage could not find anything wrong with the suspension, drop links etc all ok. So I'm going to leave it and see if it gets worse.
    Jan 2010
    FIFE
    Mine is a 52 plate and the power steering fluid resivior is under the drivers side headlight, have to remove airfilter box to get fluid in, luckly it has only needed to be topped up twice in 5 years.
    what design genuis thought of putting it there!!
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Steering rack leak
    By ldanieli in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2012, 19:53
vectra power steering leak
