Results 1 to 10 of 20
Thread: Tyre Noise
    Regular Member SRI456's Avatar
    Northants
    Default Tyre Noise
    Vauxhall had my car today for what i thought was a dodgy wheel bearing, turns out it is the front tyres making all the noise so can anybody recommend a good tyre to stop this noise, i have had a quick look on the net and found some Hankook Ventus V12 Evo K110 for £102 each fitted, does anybody else have these tyres, and are they any good? or should i say, are they QUIET
    Regular Member crespo's Avatar
    Bournemouth
    As a rule of thumb. Less grooves = less noise
    More grooves = more noise.
    WGAF#5
    pop em on the rear = you wont hear it as much and when there worn out replace them then
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    what tyres do you have on it at the moment fella
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    I´ve just fitted the new Continental Sport Contact 5 P on my 20´s
    The best tire I have ever tried.. So quiet, perfect in wet rainy conditions and very comfortable even in that size..
    The size is 245-30/20 in the front and 255-30/20 at the back..
    Hankook is also a very good tyre.. I have tried Hankook S1 Evo (Ventus K107) and it was a good quiet tyre.
    Sodding Typical on Sea
    I have a very quiet and cheap tyre called Minerva F105 (also known as Rotalla F105 from mytyres website) I also found that Neuton NT5000 were exceptionally quiet, plus very grippy. Was disappointed by my Michelin's they were harsh and noisy
    That's quite expensive for a Hancook, there are better tyres out there for that price
    What tyres are currently fitted (brand and size)?
    How long have the front tyres been on?
    Did you swap the tyres are they wear?
    It's unusual to get noise from "just the front"
    This suggests the tyres were left on the rear for at least 20K miles then swapped to the front, suffering from block wear
    If you inspect the inside edges you will see they may be a different texture to the centre or outside edge, this is caused by the camber on the rear axle
    On replacing the tyres, swap the rears to the front, and have a full camber alignment carried out
    Quote Originally Posted by crespo View Post
    Never heard of that one before, the noise is normally caused by the tyre material and construction type
    Larger blocks typically result in more noise
    I have compared numerous tyres
    The worst noise normally comes from hard compound directional split blocks
    The least noise normally comes from soft compound rain channel non-directional
    Compare the size of the blocks on the GoodYear GSD3 to the Dunlop ST, the Dunlop is almost half the size
    luton
    I had hankooks before, they come as standard on new hyundai's and i have had 5 in a row, they were fine in the dry, but when it rained its was like driving on ice, so in the end whenever i got one, i went and put michelins on, the difference was staggering.
    Then had goodyears on my last vectra, it understeered something cronic, put michelins on and it was so much better.
    Now have good years on my sri, can't wait to replace them with michelins. (I get them from costco, its £107 for the sri and they've got 20% off on top of that too if buy all four, worth a look)
    And they're quiet too.
    N.B, one thing about Hankooks is they have staggering grip in the snow, brilliant snow tyre
    The Michelin is also my first choice in tyres
    However I have already had one set on my Vectra C and not noticed much difference, so went back to the Good Year (about 20% cheaper than the Michelin)
    I had Michelin HX MXM 205/55R16 on both my Vectra B and Mondeo Mk3
    My local tyre distributor doesn't seem to be able to get the HX MXM in 225/45R17, I would just like to compare them!
  1. Weird tyre noise
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 13th August 2011, 20:53
  2. Funny Tyre Noise
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2009, 12:06
  3. Re tyre noise problem? can anyone help me?
    By ACE.TAG in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2009, 10:15
  4. Tyre noise?
    By GJFarquhar in forum Introduce yourself.
    Last Post: 21st July 2008, 19:47
  5. Rear tyre noise?
    By MikeD in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2007, 13:06
