Thread: Need to remove locking wheel nut
    Regular Member SRI_STU's Avatar
    Nov 2009
    solihull, birmingham
    Default Need to remove locking wheel nut
    Hi chaps, last week i got a blow out on the m6, i thought oh well i'll just put the spare on not a problem until i came to the locking wheel nut and the sodding locking key snapped
    Tried for ages trying to get it off using all sorts of tools and broke everything i had.
    In the end the rac came out and used there special tool and after 20 mins or so finally got it off.
    How do i go about taking the others off. been to vauxhall and they said there should be a card with a serial number in the box the bolts came in but low and behold there aint.
    These are the wheel bolts that have a outside rotating sleeve, collary type thing so i cant whallop a socket over it.
    Any suggestions, or if i get a pic up of 1 off the culprits and someone around brum has the same would it be possible to fly over and take these 3 out, dont want to sound cheeky but dont want it to happen again. lol
    Its like a 4 leaf clover shape ish, kind of.
    cheeRS stu
    if they are vauxhall locking nuts and the car is newer than a 2004 then any dealer should hold a set of master keys , so you should be able to go to them and get them to whip off the other 3
    New Member car-sri's Avatar
    LINCOLNSHIRE
    hi m8 you need to buy some sockets a bit smaller than the nut then drive it over the nut with some good wacks with a lump hammer that stops the coller spinning then you can just undo with your rachet . i had the same problem a few months back buy a decent socket for around £7 you should be able to use it again and again...
    good luck
    prestatyn
    its not that easy i had one where the socket got that jammed that i had to weld an extention bar to get it off in the end had to smash the outer case then use a socket good luck mate
  1. How do i remove auto fly wheel
    By neill in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 10:22
  2. Help - Remove locking wheels nuts of 2007 SRI
    By SteveBray in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 15:37
  3. Can't remove the rear wheel!!
    By C9_hardlatch in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2009, 21:14
  4. Help - can't undo locking nuts/how do you remove spinning collar?
    By nigec in forum Suspension, Wheels & Brakes
    Last Post: 19th May 2009, 20:37
  5. Remove Steering Wheel
    By archerz in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 21:33
vectra c how to remove locking wheel nut
how to remove locking wheel nuts insignis
how to remove vectra locking wheel nuts
vectra c removing wheel nuts
clover leaf locking wheel nuts
