Thread: Loss or Radio Reception after installing amps!
    Regular Member jrwilshire2003's Avatar
    Bridgend
    Default Loss or Radio Reception after installing amps!
    Hi all,
    I have a CD70 Headunit where I have just installed 2 amps a sub and some 6x9's. All works great but as soon as you turn the ignition on and the amps come on I lose radio reception from the headunit. I had the remote turn on for the amps tapped off the power antenna of the CD70 and thought this was the problem. I then changed it to the Cigarette lighter feed but the problem still persists. If I disconnect the remote lead and stopping the amps coming on all is fine. I cannot think whats causing it and I might just have to live with the poor radio reception. Any one else had this problem and sorted it? Thanks!
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Sounds like poor grounding to me
    Bridgend
    Could be. We drilled a new hole in the boot for a ground. Will give that a clean up.
    Jan 2010
    glasgow
    yip poss bad earth, u say u have a cd70 i take it u just used the auto leads unit and added it to the speaker wires? and then ran rca leads? did u make sure the wires from the auto leads unit wer on the corect way on the speaker wires? just a thout tho i dont think it would efect the reception but u never know
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Another thought aswell, is
    You haven't used the red/white aerial amp wire to trigger your speaker amp circuit have you, as any other load drawing power from the red/white wire will kill any radio aerial signal amplification.
    I think it could be pin 13 on the CD70 head-unit.
    Bridgend
    No it was the yellow wire but I have changed it to the Cig lighter wire now. Have cleaned the earths up I used and will give it another go. Seems strange but it's definately the amps causing the problem. Also regarding the other reply I used a Caliber LT6 and tapped off the speaker cables as you said and then converted it to RCA in the boot.
  1. Radio reception
    By Graeme in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2010, 23:16
  2. Amps to the Std Radio ?
    By andymagee1982 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2009, 14:43
  3. Bad radio reception fix?
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:36
  4. radio reception really bad
    By kev1983 in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2008, 19:47
  5. Radio reception
    By Perry in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2006, 10:20
