Thread: SRi 2.0T Edition 100 major issues
    May 2008
    Scottish Highlands
    Default SRi 2.0T Edition 100 major issues
    Morning guys
    I have a major issue with my engine
    This started on Saturday with a huge cloud of white smoke from the rear, then when checked the oil was nowhere to be found...i had no oil warning light come on or anything.
    Now the car starts fine, i put in a full 2 Ltr's of oil, but the car has horrendous white smoke and very sticky to drive, on first start the air intake is very erratic...like sook..sook..sook..sook instead of a constant flow it's a bit of a rhythm to it and noisyish.
    I have stopped using the car at the moment, also i did heard a kind of mechanical click click click noise then loads of white smoke again.
    I suspect turbo seals, but now not sure.....stem seals??? or just plain goosed??
    On start up this morning....loads of white smoke and coke smell, so it's dropping oil into the turbo I suspect and burning it off? then after the lumpyness was gone so was the smoke on idle. Took it to end of road and back...can hear the turbo spin up, then change gear.....puff of white smoke. No water loss
    Any ideas??
    WGAF#5
    sounds like quite a major oil leak into the turbo probably from the compressor side which is more common....(2 litres down is a lot) i wouldnt even attemp to drive it any further until correctly diagnosed as you could cause irrepreable damage to the engine and turbo and once its sucked though the exhaust system you knacker the cat as well
    get it recovered to someone who knows what their doing
    hope you get it sorted mate
    May 2008
    Scottish Highlands
    After reading andy's post.....new turbo or a recon job is required..mine is the same as his....but times the smoke by about 1000000 :P
    Oil smoke is normally blue, white is normally water.
    Have you taken the hoses off the turbo to see if they are full of oil? Check the intercooler too.
    May 2008
    Scottish Highlands
    Not taken any pipes off as yet....will do it later on and see whats going on. The smoke is white/blue....so deffo not water and i'm not losing any coolant.
    What pipes should I be looking at? Wondering if the return pipe is possibly blocked as well and dumping it into the turbo....but with the amount of smoke there is...I suspect the seals are totally shot.
  1. 2.0T Major Problems!
    By cold-chilli in forum Engine & Drivetrain
    Last Post: 24th March 2010, 17:45
  2. major help egr
    By astratovectra in forum Engine & Drivetrain
    Last Post: 6th March 2010, 17:20
  3. major thanks to axelf
    By shaun260589 in forum North East RO Vacant - ARO - Vacant
    Last Post: 1st February 2010, 11:04
  4. First major mod.....
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2009, 08:32
  5. hi need major help
    By andyg12 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th November 2008, 22:14
