Results 1 to 10 of 24
Thread: help please with disc and brake change
    uk
    Default help please with disc and brake change
    Hi guys im new to all this but this looks like the place to get the information i need. i am going to change the rear brakes and discs on my wifes vectra and want to make sure i order the right parts i want to get a kit with all the pads discs etc seen them on ebay for around 90 quid? the car is a 2003 1.8 hatchback with abs, so im guessing i will need the vented discs? dont know the size of the disc. so can any1 advise me on what to order plllllleeeasseee also when i took the rear wheel off there was no bolt in the centre so how do i remove the disc? there is a metal cover in the centre but no fixing showing or does this prise off? i thank any1 who replys and helps cause im not paying silly garage prices!!! thankyou guys
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    If you have the back wheel removed you should see the backs are not vented on a 1.8 unless the caliper has been changed. There should be a guide for this job in the how to section.
    Don't pay £90 for them either. The disc and pad kit is around £60-65+VAT at the dealer.
    Your rears will be 278mm discs and not vented, as Chris said.
    Metal cover in the centre? That's part of the disc. As chris said, have a look at the How 2 but you sound like you're not 100% sure about what you're doing? Not meant in a sarky way, just the impression i got. If so then I'd suggest paying someone to do them, it is brakes we're talking about after all.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    where abouts in the uk are you ?? I'm sure some local member wouldn't mind giving you a hand .
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The metal cover in the centre is for the sealed wheel bearing, to remove the disc there is a small grub screw holding it on. As said you don't seem to be 100% sure and brakes are a pretty serious subject to be tampering with
    uk
    Thanks 4 the replies guys, im not an expert by any means but my dads done loads so he is going to watch and talk me through it, unfortunaltley he is a little old to be getting his hands in. again thankyou i will defo write a post to let yo know how it all went or if i had to give in
    Regular Member SRI456's Avatar
    Northants
    To remove the disc you have to remove the caliper bracket, which is fixed on with two very tight bolts, then remove the securing screw from the disc, and it should just fall off.
    Regular Member Jezzy's Avatar
    S.E
    Whose going to mention the rewind tool? lol
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Shhhh, thats goin to be his next thread
    just remember the screw holding the disc on will be a torx head so will need a special tool to remove it
    ( and the rewind tool LOL)
  1. How to on disc & pads change
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2013, 23:03
  2. brake disc
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2011, 22:28
  3. brake disc
    By the fisherman in forum Handling & Braking
    Last Post: 26th June 2010, 16:04
  4. brake disc etc
    By hoochydady in forum Suspension, Wheels & Brakes
    Last Post: 6th May 2010, 12:41
  5. Brake disc set
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 09:42
