Results 1 to 2 of 2
Thread: Reading fault codes on 1.9cdti
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Default Reading fault codes on 1.9cdti
    Hi All,
    Does anytone know if the fault codes on the 19dth engine can be read without a fault code reader, I have tried the how 2s relating to using the pedals but it doesn't seem to work. its for a Facelift 55plate, and a 56 plate.
    Chris.
    PS does EGR valve fault bring on the emissions fault light or the spanner fault light?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I don't think it can be done with the CDTI's.
    As for the EGR valve if the eninge cannot detect the gas flow entering the manifold or the valve itself then it will bring on the Spanner light - and after driving for a period of time the emissions light will eventually come on too. If the valve is opening/closing when it should it may not bring up either.
    Gazza4
  1. Quick help needed reading fault codes!
    By Veccy55 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 17:08
  2. Fault Code Reading
    By Cyruskint in forum Engine & Drivetrain
    Last Post: 9th May 2012, 11:21
  3. V6 CDTi reading error codes
    By averdigi in forum Engine & Drivetrain
    Last Post: 20th October 2010, 23:54
  4. Fault Reading
    By DavieVectd120 in forum Engine & Drivetrain
    Last Post: 26th May 2010, 13:08
  5. U480 diagnostic Scanner, can engine be running when reading codes
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 11:58
https:www.vectra-c.comforumshowthread.php113399-Reading-fault-codes-on-1-9cdti
how to read fault codes on vauxhall vectra c
vectra c facelift get error codes
opel vectra c diesel p1902
read fault codes vectra cdti
vauxhall code p1902
finding fault codes on vectra
vectra C fault codes reading 2007
vauxhall vectra sri cdti fault codes
how to get fault codes on vauxhall vectra c without scanning
Vectra 1.9 cdti P1902 fault code
vauxhall vectra c diesel fault codes reading
how to read error codes on 1.9 cdti
fault codes vauxhall zafira 1.9 cdti sri 2007
vectra c error codes
how to read fault code on vectra 1.9 cdti 2007
read fault code signum
finding fault codes on 54 1.9 cdti vectra
