Thread: help pls...!
    Regular Member vauxhall-john's Avatar
    fife, scotland
    Default help pls...!
    hi guys having an issue with the vectra, i have an sri cdti 120 just after i got her i started to get a squeek noise from the aux belt area when the engine was cold and i revved the engine, now the noise was getting worse so i inspected today, took off the airbox and had a look at belt area but cant see very much, so i sprayed some WD40 in around the pulleys now the noise has gotten ten times worse, it sounds like a budgie is stuck in the engine bay and when i drive or rev the engine its really noisy..
    can anybody shed any light on this problem? i was thinking it was maybe the aux belt tensioner?? would that make such a noise if it was on its way out??
    any help would be greatly appreciated before i start throwing cash at it,
    cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Deffo sounds like the aux tensioner has had it although I believe the alternator pulley can cause problems too
    fife, scotland
    i used a socket extention and put some pressure on the body of the tensioner and the noise seemed to calm down a bit so think that might be the cause then it started again as soon as i let go,
    any idea of the cost of a belt tensioner??
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I know that the DTi ones are about 50 quid but not sure on the cdti. Pretty easy to change if your handy with a spanner too
    fife, scotland
    im not too bad with an engine so shouldnt be a hard job to do, just have to remember the way the aux belt goes back on...! can it be done from under the car from inside the wheel arch area??
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yep, the tensioner just has one centre bolt (torx head)
    fife, scotland
    cheers ma man ill give the stealers a call in the morning i think
    Regular Member old cruiser's Avatar
    slough
    Had this on my petrol 2.2 at the beginning of year and just ended up getting a new aux belt only fitted and all was well.
    Cheers pete
    fife, scotland
    hhmmm gonna take the belt and tensioner off and see if i can pin point the problem,
