Thread: Problems with Colly 915
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Problems with Colly 915
    I had a day off today waiting in for an electrician to do some work for me, so thought I would give the car a good clean.
    Washed, clayed,washed , SRP`d, then the problwms started.....
    I thought I would try the 915 Colly I had as a present. Didnt say anything on the tin about not using it in sunlight, so off I went and put a layer onthe one side of my veccy. What an absolute b*****d to get off . Seemed to go off in no time at all, and even though I have good MF (eurow) was a struggle to get it off. I then did very small areas at a time on the bonnet and roof, but had had enough by then, so went back to finish off my Poorboys, much easier........
    Is it just me? am I a nancy boy or is this stuff like glue?, is it easier on cooler days out of the sun?
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    Had same prob with similar product (fk1000p)
    First time i usedit the weather was still cool and could the whole car before it went off.
    Used it again last couple of weeks and couldnt do 1 panel before having to buff.
    Not so bad if using a machine but hell when doing by hand.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Regardless of what it says on the tin, it always wise to never apply wax in 'direct' sunlight - can leave smears and slight holograms (unless by machine as already said).
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    I did mine yesterday in the sun and while it is more difficult to remove, I wouldn't say it was that much effort.
    Did you use/keep the applicator damp & apply a really thin coat?
    I have the same microfibres, btw, they're fantastic.
    leeds
    I use Colli 915 and have done in full sun. It's ok as long as you don't put too much on and the paint is not hot to the touch
    [Ex]Admin Duncan's Avatar
    You must've(?) put on too much? 476 is a bit more 'temperamental' to being applied too thickly, but 915 is much more forgiving - but you only need a very thin coat. Even if it's a warm day, it's worth making sure that the tin is warmed up before applying so that the contents are that little bit softer and therefore easier to lift a small amount onto an applicator pad. Just leaving it out in the hot sun for a while will be enough, whilst on a cold day whacking it in the oven on a very low heat for a short time will do the trick.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    tbh i hate 915 i find it is a right pig to get off, if you are looking for one that goes on like melted butter and wipes off with ease with stunning results then go for chemical guys 50/50, after playing with a few waxes i found the 50/50 is the best all rounder
    Mileage : 000
    Victoria Concours Wax I would say is my favorite But Colinite is very good when put on correcty.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    This is why i only put collinite on in the winter time , collinite will set like concrete in direct sunlight and even applied in a shaded area should only be left on for around 20 min,s , as others have said only apply a very thin layer that way it is easy to remove , and leave the wax to cure before adding a second coat .
    and still loving it
    Regular Member Exclusive BV's Avatar
    West Midlands
    I use that showroom shine stuff (about to order my second bottle)
    You could see the steam coming off the car when I was applying it the other day with a damp cloth.
    It still came off easy as long as long as i did it straight away.
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. colly
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 18th December 2011, 21:34
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  5. colly 915 convertee
    By ditchp in forum Detailing and Car Care Discussion
    Last Post: 12th October 2008, 00:06
