Results 1 to 10 of 14
Thread: Urgent help - brake pad rewind help
    HULL
    Default Urgent help - brake pad rewind help
    Hi , Just in middle of brade pad replacement and trying to wind down the 2 hole disc , clockwise , but does not seem to be makeing any progress although turning fine, does it take a lot of winding and pressure to get the disc to go down so i can fit the new pad..??
    I HAVE HANDBRAKE OFF ALSO
    HELP URGENT PLEASE
    You do need to give it a very hard push to get it to shift backwards mate, but also make sure you've cracked open the bleed nipple...
    scotland
    yip get some pressure on it too while turning
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    is it not anticlockwise...
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    Quote Originally Posted by John35 View Post
    Think of it as a screw, clockwise will move the screw in and anti-clockwise, out
    HULL
    Spot on Guys , i got there in the end....if not i might have had to take a couple of days off work .. , especially with the Footy being on..lol
    May 2007
    Hull
    Just done mine and my bleed nipple was stuck solid..not wanting to break it off i undid the fluid reservoir against the advice in the haynes manual which said i could contaminate the abs system but it worked and went in a lot easier but watch the level of your fluid reservoir as mine overflowed slightly...saved some big blisters on the palms of my hands..lol
    Full Member Big Sig's Avatar
    Quote Originally Posted by V6VC View Post
    Some cars have a left handed thread on the callipers
    Regular Member Jezzy's Avatar
    S.E
    Old shape Mondeo...thread turns different way on N/S than on O/S. I think.
    IIRC peugeots are the same, so one side doesn't unwind itself when the handbrake is used.
  1. Help Brake rewind tool
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2013, 22:34
  2. Brake Rewind Tool
    By LeeU in forum Suspension, Wheels & Brakes
    Last Post: 10th September 2011, 11:21
  3. Rear brake rewind...
    Last Post: 21st June 2010, 19:24
  4. Brake rewind tool URGENT!!
    By Tony12 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2008, 18:50
