Thread: CDC40 Aux In
    Kent
    Default CDC40 Aux In
    I upgraded my CD30 to a CDC40 last year, but never bothered with the DAB box as I have no use for.
    Please can anyone tell me if it is possible to use the DAB input to the CDC40 as an 'aux in' for my ipod? I haven't bought any in-car hardware for the ipod yet so will get whatever is necessary if it's possible.
    I'll be getting the subwoofer output activated so if any software changes are necessary I could get them done at the same time.
    Thanks for any help.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    According to TIS, it is believed that you can indeed use the DAB input pins for AUX-in, however you would need a trigger to switch the headunit to the DAB source input for it to work correctly.
    Kent
    Thanks for that.
    At present, when I press the Tuner switch it cycles through AM, FM and then DAB, when it tells me 'DAB Box Error'. I guess that once there is a signal going into the input it would then say 'DAB' and therefore activate that input?
    Basically, I'd be fooling the head unit that it was receiving the DAB signal even though it was from the Ipod.
    I wonder if I could change the head unit to say 'Ipod' instead of 'DAB' via TECH2? That would be neat!
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    No this wont happen.
    You are getting DAB error, because the display is expecting to find one, when there isn't one present.
    You cannot change the display to say ipod in, the only options are Aux-In, (via jack socket where fitted - July 2007 onward), External-In (for telephone / bluetooth in via Telemute), AM, FM, CD, MP3-CD and DAB.
    What you'd need to do in reality is to get a DAB unit paired into the stereo system, and then replace the audio output wires from the DAB unit with the audio output wires from your Ipod.
    Kent
    Ah, I see.
    Many thanks for your help.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    The reason for this, is that all components in the car now do a bit of a hand-shake, so to speak. This is the function of the CAN ( or often called can-bus) system - it allows all "intelligent" modules to speak to each other, and they then exchange information in order of importance.
    The display sends a data signal to the DAB box...as if to say "Hello", and when it gets no reply, it then goes "oh eck!!" and reports an error message.
    If you got all three units - Screen, DAB and head-unit ready paired up, then it is merely a matter of connecting the wires up for the dab box which are: -
    1 - green/brown - left audio + to radio pin 31
    2 - shield - left audio ground to radio pin 38
    3 - green -mid speed can high - data link to display pin 17
    4 - red - permanent live - to fuse 1 (20A)
    10 - blue/red - right audio + to radio pin 32
    11 - shield - right audio ground to radio pin 38
    12 - white - mid speed can low - data link to display pin 18
    13 - brown - chassis ground
    In your case, you would not use wires 1,2,10 and 11.
    Instead you would connect up your aux input wires to the radio pins mentioned.
    hope this helps
    Kent
    That's great Robsey, thank you.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If it helps, the Red +12V feed is from the same fuse as the radio itself, so you could simply tap into the red wire in the main quadlock connector.
    I presume from the last cheary response, that all three components did indeed come paired together.
    In that case, it will indeed be a matter of connecting up the power and CAN wires to the DAB unit.
    And the audio wires to your aux-in jack socket.
    Regarding the thanks, you're welcome, that's what forums are for!!
  1. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  2. cdc40 Aux in
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2010, 00:03
  3. CDC40 and Aux in??
    By caspy in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2009, 17:06
  4. CDC40 DAB yay or nae?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2009, 16:22
  5. Cdc40 Mp3
    By SJG in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2008, 20:34
cdc40 dab aux www.vectra-c.com
cdc40 external in
