Thread: Paranoid over nothing ??
    S.Shields (Newcastle)
    Default Paranoid over nothing ??
    Hey, Ive got the 2.2 Petrol and this morning when i jumped in it, the check coolant level warning light came on.
    The car hasnt over heated or anything on my way to work which is a good 40 min drive.
    I only topped the coolant level up about 2-3 weeks ago (while engine was hot) and the time before that it was about a month ago. Im doing about 500mile a week.
    Checked under oil cap every thing seems ok, no cream, no smoke out of the rear.
    Is it possible with the Hotter weather and my high millage that I could be using more coolant?
    Or is it possible that last time i filled it while the engine was hot that there was presure in the system and when i thought it was full it acutally wasnt?
    Help please?????????
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    Mileage : 56000
    Probably a daft question, but is your expansion tank leaking?
    Had the problem a couple of months ago.
    I topped it up but it just got worse, until the fumes of coolant were coming into the cabin.
    It was leaking from the join halfway down the tank.
    Got it replaced in the end.
    2.8T Signum Design
    it all seems ok... i hope its not head gasket, the 2.2s do need there heads doing at the 100k mark like!! and am on 95
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    I have the same issue on mine (GSI) but it's not the head gasket, also went down the parnoia route too lol. Ended up buying a block test kit for peace of mind.
    Can you smell hot coolant when you get out the car sometimes? I can which I guess would confirm it's an external leak - yet to find where its coming from though!
    prestatyn
    my turbo needs it once so often doesnt bother me as its not head gasket and been like like this since purchase dads 1.8 does the same it neverever leaves the expansion tank just drops below line
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by neil3734 View Post
    Yes. Only way to be sure of the level is to look at it when engine is cold and top up accordingly. If it's warm it'll be sat at a higher level in the expansion tank. Once you have a correct level (at cold) then you'll have a reference point for future to then check periodically - when cold of course.
    If it is definitely loosing coolant then first obvious things to check are the tank itself as said above, that it isn't cracked/leaking and hoses/connections.
    Worcs/Staffs/Westmids (ish)
    Mine.... Same thing this morning.... Daft warning light.... Had to reverse back down my road and grab some water from the bottle in the garage
    Couple of neighbours looking on thinking "how the hell did he know he needed coolant?" lol
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    For reasons above, always check fluids and tyres cold.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Grumpy1954 View Post
    Exept oil. It needs to be checked on a warm engine about 5 min's after shut down.
    Keep an eye on it mate, if it does it again soon pop the coil pack off and have a look to see if there's any water down there, especially in the plug sockets, the 2.2 head is prone to cracking around plug #4.
  1. paranoid DMF noise
    Last Post: 1st December 2014, 15:24
  2. Got a problem. Car making me paranoid. Help please!!!
    By 123rado in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 11:50
  3. Time to drive to France again...am I getting paranoid??
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 19:15
  4. Am I Being Overly Paranoid?
    By AntB in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2008, 23:28
  5. Not sure if I'm being paranoid....
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2007, 08:46
