Thread: how much front suspension travel???
    Regular Member hagga's Avatar
    kingswinford
    Default how much front suspension travel???
    sounds a daft question.. how much generally does the suspension travel upwards.. got -45 pi springs.....asking due to...
    tis a lil close .. if an issue options are.. raise suspension(nooooooo!)... flare arches slightly...reduce tyre width or give it some neg camber.. would rather keep as is though so any help muchly welcomed
    Full Member Big Sig's Avatar
    I'd suggest altering the arch or getting a few mm machined off the wheel to allow it to sit further in as that will catch. Altering the camber will just kill the tyres.
    kingswinford
    don't really wanna go down machining route...just had the centre bores machined out..
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does it rub? A tip I always like was to get some chalk and rub it on to the outside of the tyre the take it for a drive along a rough road, that way you can see how much the tyre is rubbing and where it is rubbing against.
    Worked on my mk3 fiesta, I then had to get the rear arches trimmed
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Is it just the front you think you'll have issues with?
    My astra used to catch on front because of the weird way the platic inner arch connects to the wing. I just cut a couple of inch in to take out the lip... Think the vec has similar but only feels like 1cm or so...?!?
  1. Front suspension
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2012, 15:25
  2. front suspension????
    By Tayla in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2010, 17:28
  3. Front Suspension...
    By dankidd in forum Suspension, Wheels & Brakes
    Last Post: 30th October 2008, 01:04
  4. O/S Front suspension again!
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2007, 09:37
how much for suspension vectra c
