Thread: immobiliser question and emission light
    Brockley-south london
    Default immobiliser question and emission light
    If i had an immobiliser problem what should i expect?
    The car is a 2006 vxr. The car/spanner light goes out but the emissions light stays on. the car turns over, fuels and sparks but doesn't start. I have the wrong clocks in the car but no fault codes at all.
    From experience with my old gsi it would bring up a padlock light (facelifts don't have this) and everything is dead and won't turn over at all. Is this what I would expect if i had an immobiliser fault this time.
    Also what effect does the emission light have on the car?
    cheers
    11 Post(s)
    If there is an immobiliser related fault then the car / spanner light will flash on and off.
    The emmissions light will stay on until the car is started as it needs to monitor emmissions, which can only be done once the engine is running.
    thank you
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Normally immobilsier faults will cause the padlock sign to come on and not the spanner light, it will be a steady padlock and wont flash.. the older veccy b's use to flash the glowplug coil light if there was an immo fault (just for info's sake )
    11 Post(s)
    Plasma, the OP's car is a 2006 Vectra.
    Vx had ditched the padlock symbol by then and just use the car/spanner light (flashing) to notify of an immobiliser fault.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Why does it have the wrong clocks in it.
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    I stand corrected (well I'm sitting, so i sit corrected)
  1. immobiliser light 1.8Ls (sorry i posted in wrong section)
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 25th February 2011, 10:58
  2. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  3. help with emission light
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 10th July 2008, 02:02
  4. Engine Electronics/Immobiliser Light
    By Keyboard in forum Engine & Drivetrain
    Last Post: 4th January 2008, 19:23
  5. Immobiliser Question
    By stevie b in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2007, 22:03
