Thread: inlet manifold cleaning
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default inlet manifold cleaning
    anybody got any advice or pics of how to clean inlet manifold were egr and boost sensor goes?
    a member on here gave me a step by step but if anybody has any pics of a guide
    Oct 2009
    Sandwell
    Quote Originally Posted by chris1804 View Post
    for the dti
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    This is for the vectra b dti,so once you take the electronic egr valve off from your vectra c,this pdf has some pics of the swirl chamber which needs cleaning out.
    http://myweb.tiscali.co.uk/mozzer/ho...ectorseals.pdf
    Oct 2009
    Sandwell
    is this an easy job then? i might as well do the leak off pipes at the same time?
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    I've never done it on a vectra c,only on a vectra b,its not too bad to do though,just take your time and don't drop anything inside the inlet side of the head.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Go to the search section and type in ' exhaust manifold , boost sensor and egr cleaned ' . this will give you a set of pics showing you the manifold and egr broken down .
  1. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  2. 2.2 direct sri inlet manifold removal/cleaning
    By leem82 in forum Engine & Drivetrain
    Last Post: 4th August 2010, 11:53
  3. inlet manifold..
    By johnnyhg in forum Engine & Drivetrain
    Last Post: 25th March 2010, 23:03
  4. Inlet manifold!!!
    By darrenmac in forum Engine & Drivetrain
    Last Post: 25th March 2010, 18:34
  5. Cleaning the inlet manifold on the V6CDTi - Pics inside
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 13:02
