Thread: wheel spacers
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default wheel spacers
    as above, has anyone fitted 32mm rears and 10mm fronts when lowered on pi's 40/45mm..........using 18" blade vectra alloys? i'm thinking of doing so if any one can help
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    No, but i think you should just do it and let me know if they catch...
    I had a plumb line to the arches the other day and i fancy 15mm fronts with 25/30mm rears...
    Jun 2009
    bradford
    Smile
    Quote Originally Posted by leemarksmith View Post
    lol...........guess if they do i can get them machined on the miller
    they are damn expensive tho..........£100 for the 32mm
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    These do 15mm (BARGAIN) and 20mm for a fairly decent price...
    http://magnex.net/frame-detail.asp?P...loy-wheels.asp
    And H&R.
    http://magnex.net/framefix-detrange2...ACTURERS=19657
    Camber on the rear of mine is well off and needs sorting but the rears seem to be able to come out a good 10mm over the fronts. Be good to see my snowies pushed out a little. But holidays and DIY stuff means i'm trying to do all the cheap and easy stuff 1st
    Regular Member hagga's Avatar
    kingswinford
    10mm front shouldn't be an issue..nor should 32mm rears..depending on tyre width.. the rears can be spaced out loads due to the suspension travel moving in an arc rather than straight up
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by hagga View Post
    I measured the fronts and looked about 18/20mm clearance, so i was thinking the 15mm up front (when i eventually get some)... What was the max size you had on your old setup?
    kingswinford
    i had 10mm on front... but what you can have is more down to tyre width and offset.... having a similar issue myself..but without spacers lol http://www.vectra-c.com/forum/showthread.php?t=113333
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Well i'm on 19 snowies with standard tire sizes, so maybe some clever person can work out the maths for me
    Otherwise 10 and 20mm it is, just to be safe
    By way, haven't you got a fat mate that can sit on your slam panel while you take a look
    kingswinford
    lmfao!!!! no...but i could nip up town late n 'pull a porker'
    Regular Member Signum Dek's Avatar
    South Yorkshire
    I've got 18" x 8" wheels with an offset of ET45, fitted with 235 x 40 tyres, and am currently using 22mm spacers on the rear and 18mm on the front, with no problems, but thats on a Signum.
    Dek
  1. Wheel spacers ,yes or no?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 12:40
  2. Wheel spacers
    By vxpenfold in forum Handling & Braking
    Last Post: 5th February 2012, 10:45
  3. wheel spacers , has anyone?
    By melvyn8181 in forum Styling
    Last Post: 12th October 2011, 10:26
  4. wheel spacers ? should i fit them?
    By pogo in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2010, 21:44
vectra c sri wheel spacers
