Thread: NCDC 2013/2015 Install
    Nottingham
    Default NCDC 2013/2015 Install
    Hi guys,
    My NCDC 2013 packed up and i purchased what I was told was a new NCDC 2015 head unit.
    Problem is that the unit when installed brings up the display safe sign on the screen.
    Is there any solution. Should I get theunit back to 'factory settings' and hopefully this should work?
    Any help would be appreciated!!!!
    You need to paired to the car, but in order for this to happen it does need to be in delivery mode.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    or sent it to a firm that can reset and recode it to your car.. without beeing in the car..
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You need to get tech2 on it and check delivery status to make sure its in delivery mode,then get them to pair it to your screen using your security code
    Irmscher Insignia CDTI 130
    Nottingham
    Thanks guys...I know a firm in Birmingtham that can definetely get teh unit into delivery mode.
    Will get this done and see if it works...
    Fingers Crossed!
    Will keep you updated
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You might be best trying dealer first mate else you will pay someone to decode then another to code
    Might be best to leave it installed and just nip to your local vauxhall and ask if anyone has 2 mins spare just to tell if its still coded all you will need is to know what the security status is if its set the delivery then your ok to code
  1. Ncdc 2015
    By hardin in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2011, 06:33
  2. Ncdc 2015
    By Signum Dek in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2010, 09:02
  3. Ncdc 2015 - cid & tpms
    By stoneshed in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2009, 12:01
  4. NCDC 2015 Sat Nat Question
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2009, 21:40
ncdc 2015 pin
how to put codes into ncdc 2015
