Results 1 to 10 of 13
Thread: squeaky brakes
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default squeaky brakes
    my brakes have started to squeak, when i apply light braking they squeak but when i brake with more force they dont, any ideas???
    Jan 2010
    wirral
    same here, i await some responses
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Same here m8
    WGAF#5
    glazing on the surface of the pads - this is more common now that they dont allow asbestos in the pads which used to lubricate them when applied... now you have a higher concentration of metal on metal which casues rotor resonance when you apply the brakes LIGHTLY if there squealing at any other speeds (over 10 mph) then there is another issue
    this is also more common when there still cold and SOMETIMES disappears when there hot - but not always
    lots of manufacturers are suffering with the issue - best option it to remove the pads and rough up the suface this will help - but they need to be bedded back in - you can also try chamfering the edges of the pads this will decrease the leading surface area =which will increase the pressure on the face (stillehtoe effect) which helps decrease the squeals...but can also cause lipping on the discs ....the final option is to try another make and hope that they come with noise suppresson shims (metal plates that have small springs on them) which buffers the brakes and stops the noise as well
    HTH
    regards
    Dez
    Oct 2009
    Sandwell
    so you should only notice below 10mph, mine happens at any speed, but there is loads of life left in the pads
    PRESTON
    ditto chris, osf on mine squeals slighty at any speed with light pressure, but goes of as you depress the pedal. plenty meat still on pads.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Did you apply any coppaslip to the backs of the pads and sliding contact surfaces on the edge of the pad backing as without this they squeek something awful.
    Regular Member DaveW555's Avatar
    Cannock
    Cheap pads without the shims give this problem a lot, try some better pads (with the shims) with new slider plates and plenty of copper grease that should shut them up.
    WGAF#5
    sorry guys just to clarify == the noise if present at over 10 mph i was expecting you to be braking heavier ..... rather than lightly ... as this could be worn brakes with heavy braking ...or stones stuck on the brake pads face
    as i said its probabably going to be as per my first post and DaveW555 seems to agree noise suppression shims will/should resolve the issues
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    I do know someone who once put wd40 on his brakes to stop them squeaking...... come to think of it; stopped him stopping too lol
  1. What causes Squeaky Brakes (Vec-B)
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 09:47
  2. Squeaky Brakes
    By BENNYBED in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2008, 14:44
  3. Squeaky Brakes
    By smithi in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2007, 15:03
  4. Squeaky Brakes??
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2007, 15:49
  5. Squeaky Brakes
    By tj 666 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2007, 23:18
