Thread: Pedal trick
    KENT
    Default Pedal trick
    Can anyone direct me to how/ where I can find the 'pedal trick'. I remember reading it somehwere here. I have just cleaned the egr due to yellow spanner light flashing. I understand there is also a pedal trcik you can do to reset something???
    Any ideas?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Pedal trick is to check for stored fault codes. Doesn't work on Dti's though
    If you are trying to clear a stored code then disconnect the battery for 15mins (make sure you have the radio code though)
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The 'pedal trick' to which you refer is a method to cause stored fault codes to be displayed by counting the flashes of a dash lamp.
    If you're trying to clear the current fault lamp (EML) then you have a choice of ignoring it until the car has had (typically) 20 'good' starts without that fault recurring whereby the lamp goes out by itself, or you can disconnect the battery for about 15 mins (1 hour usually recommended) which should cause the ECU to 'reboot'. Just make sure you have things like radio codes to hand before you try it in case you need them upon reconnecting.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Excellent advice
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Handyandy-UK View Post
    Excellent advice
    Mine is the "diet" version all of the taste none of the sugar
    KENT
    Ohhhhh I see! Right discon the battery it is!!! thanks guys for the PROMPT reply!
    I knew the answer would be here in seconds!
    11 Post(s)
    Quote Originally Posted by 123ashleyp View Post
    It's in the how2 section of all places.
  1. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  2. Replies: 1
  3. Pedal trick Facelift
    Last Post: 11th October 2010, 08:58
  4. And for my next trick..........
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 21:05
  5. Gordon's trick
    By Doug-SRidirect in forum Comedy & Humour
    Last Post: 2nd February 2006, 14:14
insignia pedal trick
how do you do vectra c pedal trick
vectra c pedal trick test
opel vectra c pedal trick
how to pedal trick on insignia
is there pedal trick test for a insignia
vectra c pedaltrick
vauxhall vectra pedal trick
