Results 1 to 3 of 3
Thread: broken electric window??
    New Member BiggDaddyT's Avatar
    Newcastle
    Default broken electric window??
    last nyt i put down my back drivers side electric window, and heard an nasty sound, now my problem is this :-
    the window not move up and down with the motor, th motor goes down and th glass has to be pushd down by hand, bt the motor is stil working as it push th glass back up, an locks it at th top, wat do i do to fix this????
    Ashington, Northumberland
    Sounds like the regulator has become detached from the glass. There are two clips (one at each end) of the glass, they're 'U' shaped and the glass sits in them and a bolt tightens them onto the glass. Sounds like they have worked loose and when you put the window down, the regulator is dropping but not taking the glass with it because it isn't anchored to it anymore, but when you put it up it operates normally because the clips push up against the glass. Take the door card off and check
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Iv got the same problem! black clip part number 24462197 holds glass to regulater
  1. Broken front electric window regulator
    By alanatrr in forum Bodywork & Interior
    Last Post: 14th April 2013, 11:22
  2. broken window wipers stalk
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2011, 15:56
  3. Electric Window
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 16:20
  4. Electric window help
    By manimal in forum Bodywork & Interior
    Last Post: 19th November 2010, 22:10
  5. Electric Window Help
    By Digital_kid in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2007, 18:58
