Thread: Vec B ABS Light Help Needed
    Regular Member PORKBALLS29's Avatar
    Epping
    Default Vec B ABS Light Help Needed
    Hi all,
    A chap at work has a 2001 Vec b 1.8 and the ABS light has been coming on intermittently for a few months but now it is more regular. He's had the wheels off and checked pads, calipers and sensor and they all seem to be ok. Does any body have any suggestions as to where to go from here? Is there any way of reading the code without a reader like on the Vec C?
    Cheers Howard
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Plasma will probibly have an answer when he decides to wake up .
    Epping
    Quote Originally Posted by soulman View Post
    Wakey Wakey Mr Plasma! Unless the ants have eaten him. Lol.....
    5 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    LOL@ Howard
    WGAF#5
    Howard make sure there is no rust or corrosion near the sensor as this will cause false readings and the sensor light tom come o. If it's not seated correctly
    Admin plasma's Avatar
    On the Forum
    216 Post(s)
    Engine : 150
    Mileage : 74000
    Not got any advice to offer on this one really, had the same issue on my current vec b but it the abs light hasnt come on (touch wood) since I changed the rear discs and pads, so all I can imagine is its a bad connection somewhere...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Epping
    Ok cheers guys will have to have a look at the rears aswell.
    Regular Member old cruiser's Avatar
    slough
    A mate of mine had this same thing on his 1999 1.8 Vec B a short while ago, he tried all sorts to fix it including giving it to a very experienced mechanic who also couldn't find it, strange thing was that his battery gave up the ghost several months later, fitted a new battery and fault disappeared, so whether the iffy battery was supplying a lower than normal voltage to one of the sensors I don't know, but as far as I know his car is still ok.
    Cheers Pete
    S.Shields (Newcastle)
    My ABS used to come on, on my SRi 140 and the speedo will stop working randomly... Its was the hub that was at fault. The problem only happened if i stood on the brake a touch hard it was the teeth or summit
  1. brake light help needed
    By chrisg in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2011, 11:36
  2. Light Cut polish needed..
    By Dwabo in forum Detailing and Car Care Discussion
    Last Post: 4th March 2011, 17:30
  3. help needed t/c light
    By bigbrox in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2010, 19:55
  4. Head light help needed
    By tony stoney in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2009, 13:05
