Results 1 to 10 of 15
Thread: Hi all Im trying to solve this problem
    wigan
    Default Hi all Im trying to solve this problem
    I have a 2005 55 reg vx estate 19 cdti 150. Had it for approx 8 months with no problems until the EGR valve went, I have had this replaced, that solved that problem but found that the bar on the swirl flaps had come of, I managed to get the bar back on. Now I'm getting a juddering at low rpm and it feels sluggish on the motorway doing around 70 - 80 mph just wondering if anybody could help.
    I have tried putting redex in with diesel and tried using bp diesel instead of anybodys have been doing so for around a month now.
    The engine number is 17008642 so looking on hear it doesn't appear to be the third injector plug.
    scotland
    boost sensor? Sorry sounds like your inlet manifold is gubbed
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Could be vacuum boost pipes mate worth replacing just for the extra throttle response see the sticky thread at rh top of this section there are pics and instruction to do it takes all of 2mins and makes a vast improvement on my veccy estate
    Or could be dreaded dpf becoming blocked up
    wigan
    UPDATE
    Hi all changed my boost pipes put some silicone ones on, had my inlet manifold replaced yesterday to the cost of £500 this included 4 hours labour and a diagnostic check which said there were no faults at all. Drove it back from the garage and still having the same problem as before it feels like it judders when you are crusing. If your firm with the accelarator then you dont notice it is there anything else this might be as it's becoming frustrating
    salisbury
    3rd injector wiring? or fuel fuel filter blocked? or as i have found one of a million things!
    these engines are a fricking mystery to me>
    good luck
    wigan
    tell me about it this is the second one i've had in 2 years the first was in the garage every month for the same problem luckily it was under warranty. Unfortunatly this one isn't. So trying to do it on the cheap.
    Regular Member kamar's Avatar
    bradford
    mate get the 3rd injector plug changed mine had this problem its now 100%. my bar of the inlet is off to but the car drives fine its fast economical etc...with no smoke or lights
    Birmingham
    I also reckon the juddering points towards the 3rd injector. £15 DIY job, worth doing!
    Bye bye Vec B
    - Hello Siggy!
    wigan
    I had someone look at the third injector wire and it looked ok. there was no corrosion on it but you never know it may still be faulty so I will give it a try for that kind of price.
    Farnborough, Hampshire
    Hi
    Today I have done the following...
    Changed the boost valve pipes,
    Cleaned the EGR valve (and as much of the inlet as i could get to with the carb cleaner),
    Cleaned the boost sensor,
    Changed the diesel filter and
    Replaced the alternator (cos it died)
    Air box mod
    Busy day, but what a difference!! Got rid of the same cruising 'judder' you describe (touch wood).
    I found the boost sensor caked in crap, EGR valve sticking (solenoid moved freely but drilled the hole anyway and greased it up), and the fuel filter nicely gunked up, all on a 37,000 mile engine.
    I reckon if you try this lil lot it will solve a lot of your problems. really hoping this is it, the car and spanner light didn't even come on so fingers crossed this is everything sorted for now
  1. Anyone solve this
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2012, 21:13
  2. Can anyone please solve this mystery?! Desperate to have a working car again!
    By neskemi in forum Vectra C / Signum Troubleshooting
    Last Post: 18th May 2012, 17:44
  3. Getogether to try solve my abs
    By twaiter in forum West Scotland
    Last Post: 7th May 2010, 09:06
  4. Solve the V6 diesel enigma
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2009, 19:04
  5. Does the No 3 injector wiring really solve the misfire?
    By bygumlad in forum Engine & Drivetrain
    Last Post: 13th April 2009, 16:40
