Thread: Radiator cooling fans – intermittant on/off - not at temp
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Radiator cooling fans – intermittant on/off - not at temp
    With the hot weather I had the front windows down and I can hear the electric fans running not long after I start the car from cold.
    Temp guage is still showning cold but fans run on/off for typically less than 10 secs in each state.
    Any ideas guys why the electric fans are kicking in - only noticed as I have the windows open?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    have you got your aircon on ...or does it have climate control ? ...
    Jul 2006
    greenock
    Quote Originally Posted by benny View Post
    It has climate control rather than AC?
    It may be normal, only noticed the fans were running as the windows were open - don't remember it doing it before but may not have noticed.
    11 Post(s)
    It'll be the other fan you're hearing that's for the condenser.
    Feb 2006
    dudley
    yeah the air con runs all the time with climate so the cooling fans are used to keep it cool ....would also make the car warm up slower in the winter ...option in menu to turn it off ....
    Jul 2006
    greenock
    Thanks guys, sounds like its normal then - just I have never clocked it.
    It's a pre-facelift, don't remember seeing option to turn this off.
    Can I trick the system to check the fans don't always run - set higher temp on climate control dials?
    11 Post(s)
    Quote Originally Posted by Swatty View Post
    Try turning the fan speed to zero, but you should be able to turn the CC off by pressing in the large control knob which then takes you into the menu which should be displayed on the radio display.
    The AC system itself will run at the same temperature regardless what you set the internal temperature to. All the temp control inside the car does is control the amount of hot coolant that passes though the heater matrix.
    Jul 2006
    greenock
    Try turning the fan speed to zero.
    Thanks Big Dave, I will give that a try, cheers Glad it is normal, had the car for years but never noticed it
    Glasgow
    Or you can simply turn the air con off by unclicking it from the menu.
    Jul 2006
    greenock
    I remember about the control screen on the display but I only remember the option to change the direction of air flow - will check it tomorrow - Ta
  1. Cooling Fans
    By Griff72 in forum Engine & Drivetrain
    Last Post: 15th August 2012, 17:57
  2. Changing dual cooling fans
    By Jonsey in forum Engine & Drivetrain
    Last Post: 4th July 2011, 21:59
  3. Engine Cooling fans working correctly?
    By luke4487 in forum Engine & Drivetrain
    Last Post: 28th April 2011, 11:15
  4. Cooling fans run constant - Vectra c 3.2 V6
    By pawlo in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2010, 20:04
  5. Cooling fans
    By Darrell Lossau in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd February 2009, 22:18
