Results 1 to 3 of 3
Thread: drivers side window
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default drivers side window
    been messing about setting the anti hijack feature today, but now the drivers side window only operates in stages, before i could press the button once and the window would fully go down.
    now i have to keep it pressed and the window will go down a bit at a time if i press the button continusly, any one know how to reverse this function
    Regular Member Jezzy's Avatar
    S.E
    Try resetting it - press the button to close the window and keep it pressed for a couple of seconds even after it's closed, then press it to open, keep the button pressed, hold it for another couple of seconds even after fully open.
    [Ex]Admin Duncan's Avatar
    Have you tried resetting the window?
    Wind it down, then wind up but keep button pushed all the time as it goes up, keeping it pushed once it's closed until you hear a faint click. Then it should be back to normal.
  1. Drivers side window come off hanger
    By djlee in forum Troubleshooting
    Last Post: 26th June 2012, 18:25
  2. Drivers side window
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2011, 21:08
  3. Drivers Side Window???
    By mikeq in forum Bodywork & Interior
    Last Post: 11th February 2010, 13:18
  4. rear drivers side window not working 52plate
    By gsisi in forum Bodywork & Interior
    Last Post: 18th May 2009, 21:53
  5. drivers side window problem
    By kgsric in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2006, 08:37
signum drivers window goes up when press down
