Results 1 to 10 of 23
Thread: Check Safeguard
    Regular Member Dazzy2006's Avatar
    Notts
    Default Check Safeguard
    I've got the dreaded check safeguard message every time i start the car
    But after doing a search on here i think its my own fault because yesterday i decided to remove the diy tinting film from all the rear windows which was fitted (badly) by the previous owner
    So im guessing that i have probably bust the heated rear window element but what i want to know is there a way i can bypass it or is it only possible on estates
    WGAF#5
    sound the case mate
    temp repair you could use the heated screen repair stuff that comes in a nail varnish type application -tape either side to mask the are that needs to be repaired and then apply - leave to dry and then apply another coat and then remove the tape BEFORE its completely dry to ensure you dont damage the connections again
    Mileage : 000
    I don,t know how you can by pass it. Might be possible to do. But yes I think only the estate has the sensor strips on the rear side windows. There have been one or two members who have reported that they have "damaged" the sensor strip wire. But I can not remember what their outcome was.
    Notts
    Damn, looks like i will have to try fixing the heated element, i might learn 1 day to stop messing around with the car
    But then again i doubt it
    Notts
    - i'm a bit baffled now because i just checked the rear screen element and it looks intact,no breaks or anything - does anyone know which fuse it is in the boot 4 the alarm as im hoping maybe that has blown
    Regular Member madman's Avatar
    nottm
    i believe its fuse 23. i had this on my estate. removed the fuse and no more alarm going off all the time. the alarm is still active for all other sensors. you could even do the alarm 'mod' while you're in there. you may have to remove the fuse box, then remove the plug to the siren. it should re-route through the horn.
    Full Member spennny's Avatar
    Blantyre
    Check the fuses in the boot area , left hand side ,
    Notts
    Thanks.I'll check the fuse in the morning but the alarm isnt going off, in fact the light in the dash isnt even flashing,thats y im hoping its the fuse - i just keep getting the check safeguard message every time i start the car.
    I have tested the rear heated window and thats definately bust so if it isnt the fuse i'm hoping that if i short the wires together to the heated window it will complete the circuit and get rid of the message.
    Mind u i will then have 2 remember not to use the heated window
    WGAF#5
    Quote Originally Posted by Dazzy2006 View Post
    if you use the heated screen repair stuff as per my post it will still work
    Quote Originally Posted by ed taylor View Post
    Pretty sure they just linked up the wires from each side of the car.
  1. Safeguard Check.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 17:43
  2. Check Safeguard
    By Tam80 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 08:43
  3. Check Safeguard
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 22:51
  4. Check Safeguard
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2010, 22:41
  5. Check Safeguard (Again)
    By stevem in forum Troubleshooting
    Last Post: 6th August 2008, 19:31
how to bypass safeguard on a vectra c
check safe guard light on vauxhall vectra 3.2 v6
