Thread: Astra G/Mk4 - Coolant Query!
    Birmingham
    Default Astra G/Mk4 - Coolant Query!
    Quick one for you chaps,
    We got a Mk4 1.6 LS 8v on an 02-reg.
    Its using water, but not loads, every couple of weeks it goes down just below the seam, then I fill to just over and then it goes down again when I next check.
    Im not getting mayo, apart from when the car has done really short journey's over a week (misses uses it to drop the lad at nursery). When I drive it on a weekend I usually use it for a good 15-20 miles and do give it some welly just to clear any crud, etc, and after the oil cap and rocker cover is clean as a whistle, no mayo, just normal oil-not even wattery).
    The car isnt dripping water anywhere, nor is there any water in any of the internal footwell's.
    My question is, is this normal for it to be using that much so often, or is it going somewhere and is there an underlying issue?
    Any feedback would be great.
    Oh and its not overheating, temp working perfect, going up and down as it should.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    TBH you shouldn't be using any water, have the timing belt and water pump been done? I'd be checking that the water pump isn't leaking
    Birmingham
    Yes they have both been done just before I bought it.
    Bye bye Vec B
    - Hello Siggy!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Double check the pump isn't leaking, if the rubber o ring hasn't seated right then you'll get a leak
    Regular Member Exclusive BV's Avatar
    West Midlands
    Check the seams on the expansion bottle. These have been known to leak fluid under pressure when the engine is hot.
    There could even be a hairline crack in it somewhere which is watertight when cool but leaks under pressure.
  1. Is it Astra h or Astra j gearstick that fits vec c
    By jon1.9cdti in forum Bodywork & Interior
    Last Post: 10th May 2012, 07:28
  2. Coolant top up and pressure cap query
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 15:18
  3. Oil cooler replacement & Coolant Flush query
    By kon123 in forum Engine & Drivetrain
    Last Post: 29th September 2009, 19:47
  4. GM Oil query
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2006, 11:43
  5. 5th Gear - 888 Astra vs Astra VXR
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2006, 00:26
my coolant on my astra mk4 goes down after a few days
