Results 1 to 10 of 15
Thread: quick helpp
    Regular Member vectra_'s Avatar
    australia
    Default quick helpp
    hi, i was just trying to fit the insignia jets..i fitted the one on the drivers side but on the passenger sides one, its just dosnt come off, i pull like hardest i can, still doesnt come of.. what should i do??
    also how do we adjust these, do we need that special tool ? :s
    Try warming the pipe up. Put the lot into some hot water or carefully warm it with a hot air gun etc.
    australia
    maybe a lighter??
    just warm the old jet up you mean yeh?
    Where the hose connects. Just be careful you don't burn it.
    WGAF#5
    which part is stuck ...the pipe or the jet?? if its the pipe then pull and it will give ...if its the jet place a small piece of wood on top and then hit carefully with a hammer to pop it out
    as regards to adjustments .....there is a how2 on here to make a tool from a pen lid ...or theres a bloke on ebay ripping people off to the tune of about a fiver !!
    regards
    Dez
    australia
    nah the jet comes out but the hose connection doesnt come out.. :/
    WGAF#5
    it is Hyper tight ...
    if you have the new pipe with both new jets conencted you might find its sufficiently long enough to "snip" the old one just past the connector - just offer it up to see if you have any "spare" mine was over long when I purchased them ...but still managed to Pull the little blighter apart
    australia
    what you mean by offer it up ? :/
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    hot water on the pipe! it will come off easy then.
    WGAF#5
    Quote Originally Posted by vectra_ View Post
    sorry mate = put it as close as possible to where its going to be mounted (i.e. fit the jets and feed the new pipe to where the current connector is that your having an issue with) then hopefully you have an excess amount of pipe near the connector you should be able to see how much extra and cut the pipe on the old one to "compensate" for the new and rejoin from there ....probably as clear as mud ...
    Hth
    other option is to cut the old pipe CAREFULLY with a craft knife on the washer jet side of the connection to allow it more movement and to open up the connector.. this way you not damaging the part you need
    regards
    Dez
  1. springs helpp
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2010, 21:27
  2. helpp pleasee :s
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th March 2010, 13:26
  3. Helpp!!
    Last Post: 20th February 2010, 08:55
  4. helpp :) duno wat is wat :)
    By ben2996 in forum Detailing and Car Care Discussion
    Last Post: 7th February 2010, 00:10
  5. best tuning.. helpp!!
    By ben2996 in forum Petrol Engine related
    Last Post: 4th February 2010, 02:16
