Thread: Door-to-door lighting
    Regular Member dbrook007's Avatar
    Yorkshire
    Question Door-to-door lighting
    How do I get my door to door lighting to work properly?
    It will work when I use the remote to unlock/open the car but when I lock the car no lights come on.
    Do I need to do something in particular? Is there a setting or something?
    Darren
    Regular Member doughy's Avatar
    Jan 2010
    Wisbech, Cambridgeshire
    Trim : Exclusive
    Engine : 1.8VVT
    Mileage : 53000
    When turning off the ignition and getting out just flash your headlights and they will stay on for 30 secs. Im not aware of them coming on when going to your car.
    Mar 2007
    North East
    As above, flash headlights and they stay on for a while. No other setting bar the "find me" which is the lights coming on when you unlock the car.
    Yorkshire
    Question door to door
    I can't seem to get this to work...
    Do I flash the lights before turning the engine off?
    Do I flash the lights before taking the key out?
    Will the lights stay on for 30 seconds if I get out and lock the car straight away?
    Darren
    Chester
    According to the manual:
    1. Switch off ignition
    2. Remove ignition key
    3. Open driver's door
    4. Pull turn signal lever
    5. Close door.
    The time the lights stay on for can be adjusted in the menu settings.
    West
    As above... flash headlights after opening the door with the keys out
    Yorkshire
    Smile
    Cheers, thanks... it was the not opening the door at the right time where i went wrong, much appreciated, thx
  1. drivers door lighting switch
    By beggsy in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2012, 21:27
  2. 02MY Door courtesy Lighting
    By insignia28 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 10:22
  3. Recycling Irmscher Door Sill Plates and Door Pillar Trims
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2008, 19:08
vectra c find me lights
