Thread: ciggy lighter
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default ciggy lighter
    ive bought a ciggy lighter from e bay vx logo , when i have tried it it does not work, ive got the flap thing covering the slot,
    ive heard loads of stuff about wether it is aux or not ?
    i have just replaced the fuse as that had blown, phone charger works but mot the ciggy lighter ?
    i have also removed the ash tray to find there is 2 wires to the lighter and also a connector that is not attached to anything, any ideas
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    The connector have a yellow/grey wire... Thats for the light on the cig surround...
    Not sure if correct but think you need to replace the power slot with a cig one...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The spare wires will probably be for the ashtray illumination if you don't have it fitted
    Jul 2009
    The Rift, Cardiff
    My cig lighter socket has three wires going to it,
    black - ignition live
    Yellow/grey - illumination
    Brown - earth
    The other connector you have will be for the ashtray illumination, an led that clips onto the side of the ashtray housing.
    [Ex]Admin Duncan's Avatar
    If you've got the 12v socket, are you interested in swapping it for the ciggy lighter that I have in my car - and never use. I'd need the socket assembly as well as the trim that goes around the socket - the grey painted part - as it's slightly different on each type. I'd send you the ciggy lighter complete and my bit of corresponding trim.
    Feb 2006
    north east
    happy to do that duncan , so will that mean i will have a fully working ciggy lighter and the no extra wiring needed, also will the trim match in colour / is it easy enough to remove everything duncan
    Yep, you should have a fully working ciggy lighter as it sounds like you have all the wiring there, including the one for the ashtray.
    I'm assuming the trim will match as I'm assuming you have the metallic grey trim that is in all/most of our cars?
  1. Ciggy lighter
    Last Post: 9th September 2009, 22:41
  2. ciggy lighter help
    By Clugie in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2009, 17:31
  3. Ciggy lighter dead
    By APJ in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2007, 12:15
  4. ciggy lighter
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2006, 21:29
