Results 1 to 10 of 14
Thread: Z22YH - 2.2 16v Ecotec Direct Spec Sheet
    Scunthorpe
    Default Z22YH - 2.2 16v Ecotec Direct Spec Sheet
    Engine Specification
    Engine, location:
    Front, transverse in front of axle, 10 º backward inclined
    Cooling system: Liquid, sealed circuit
    Cylinders, number: 4
    Bore (mm): 86
    Stroke (mm): 94.6
    Displacement (cc): 2198
    Compression ratio: 12: 01
    Engine, type: In line; 5 main bearings
    Cylinder block/ head, material: Aluminium/ aluminium
    Camshaft (s), location: 2 overhead (2 DOHC), driven by chain
    Valve train:Indirect, roller cam followers
    Valve, arrangement: v; 4 per cylinder
    Valve, adjustment: Automatic - hydraulic
    Fuel system: Gasoline direct injection
    Ignition system: Electronic ignition map, ignition coil direct to spark plug
    Fuel pump: Electric, in tank
    Emission control system: 3 - way cat. conv. with 2 oxygen sensors
    Output (kW/hp CEE at 1/min): 114/ 155 at 5600
    Specific power (kW/l; hp/l): 51.9; 70.5
    Max. torque (Nm at 1/ min): 220 at 3800
    Specific torque (Nm/litre): 100.1
    Mean effective pressure at max. power/ max. torque (kPa):1111.4/ 1258.3
    Average piston speed (m/ s): 17.7
    Engine oil, capacity (l): 5
    Cooling capacity (l): 7.2
    Battery 12 V, capacity (Ah): 72
    Alternator 14.2 V, capacity (W): 1704
    Max. service interval: 20,000 miles or 1 year
    Emission compliance: Euro 4
    Engine mass (kg): tba
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Nice I like that Engine
    Scunthorpe
    Quote Originally Posted by Sean-2.2Direct View Post
    Yeah me to, I'll like it even more when i get some more power out of it!!!
    Apr 2008
    Liverpool
    haha were do you get the data from
    Im happy with the power mines outputting atm although i will want more hopefully soon
    Scunthorpe
    Was looking for it on google, so thought might as well post it!!!
    I'll be happy when i get 200bhp out of mine. Just standard at the mo, with air box mod and filter.
    Hopefully getting a fully stainless with sports cat and manifold, 2.4 intake, high rise sports cams and remap soon, depending on cash flow lol!!!
    Apr 2008
    Liverpool
    Quote Originally Posted by tomtaylor15 View Post
    Hopefully getting a fully stainless with manifold, 2.4 intake, cams and remap soon, depending on cash flow lol!!!
    Nice mate
    when I was on the RR last year it was 175 now I have a SS Exhaust and Kn Panel filter I reckon its around 180 to 185 now If I got it done again
    Scunthorpe
    Nice mate
    What engine mods you actully got then!!!
    Like i said 200bhp will keep me happy till i'm 23, then its VXR time!!!
    Only a year and a 9 days left!!!
    Apr 2008
    Liverpool
    None I had a kn cone filter on at the time and decent sparker plugs.
    Just general mantainance A very shiney Throttlebody and Intake manifold
    Scunthorpe
    Fair Play!!! Mines in good condition. How you clean up your throttlebody and intake manifold!!!
    Apr 2008
    Liverpool
    Carb Cleaner take TB off give that a clean then a bit of a pole with a rag to clean down in to the manifold
  1. Z20NET Spec Sheet
    By Jezzy in forum Petrol Engine related
    Last Post: 27th February 2017, 16:38
  2. What can u do to a 2.2 direct Z22YH
    By Kcriyback in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2012, 00:40
  3. 2.2 direct z22yh
    By davidlewis24 in forum Engine & Drivetrain
    Last Post: 26th May 2011, 19:34
  4. Z22YH (2.2 Direct) Misfire
    By johnmac in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:31
vectra c 2.2 direct chiptuning
z22yh tuning
chiptuning z22yhtuning z22yhz22yh service intervalsz22yh best chipz22yh valve clearancesz22yh chipopel vectra c 2.2 z22yh specsz22yh engine tuningvauxhall 2.2 direct chiptuningVauxhall Vectra C Z22YH tuning
