Thread: still vibration from clutch
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default still vibration from clutch
    Had a vibration from clutch when pressed so had a new dmf and clutch fitted luk parts vauxhall fitted them, problem is i still have the vibration in the clutch when pressed, could this be something simple like a bearing or something, i remember reading on here someone else had this prob after fitting a dmf and clutch and the stealers said the vibration was normal, anybody any thoughts on this.
    PRESTON
    have you taken it back to the dealer that fitted the parts to get there opinion? as i understand it, its normal to feel a small sensation through the clutch pedal, even when everything is ok. is it this or something louder? tbh, they would have changed the release bearing (concentric slave cylinder) with the flywheel and clutch, so doubt this will be the problem. Take it back if your not happy with it, you paid to have the job done, so get it checked,
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    yes they changed the slave cyclinder, and they gave me the old one back, only snag is i bought the parts genuine luk as vauxhall used, and vauxhall fitted them, will i still have a warrenty on the work.
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by decks View Post
    Yes you do, the Sale and Supply of Goods and Services Act says so. In lay terms it says that they should do the job properly. that said, if the parts themselves are faulty and not the garages workmanship then you would have to claim for the labour from the parts supplier which would be trickier. as the garage had upheld there part of the bargain.
    Regular Member DaveW555's Avatar
    Cannock
    I had a problem with an LUK flywheel being out of balance and it gave me a world of problems, but still whoever fitted it should have inspected the part prior to fitting.
  1. Clutch pedal vibration
    By Ianz in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:41
  2. New clutch and DMF but still vibration in pedal
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 29th September 2011, 16:54
  3. Clutch vibration
    By misterpants in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2010, 10:59
  4. clutch vibration
    By morphhprom in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 21:20
