Results 1 to 10 of 18
Thread: oil change
    Runcorn
    Default oil change
    Trying to change the oil on 2003 vectra c diesel. Everything sorted so far, just need to remove the drain plug. Presume it is the one that yer use an allen key for at the rear of sump. What is the correct way of removing it as it seems very tight. Allen key does not fit greatly and also no leverage to remove it. Is it anti clockwise to remove........Cheers...Colin
    [Ex]Admin Duncan's Avatar
    It'll be anti-clockwise. Are you definitely using the correct size of allen key? Has it been slightly rounded by a previous owner/garage? If so then be careful you don't round it off even more!
    Are you using normal allen keys? If so you may struggle to get enough leverage, especially if some idiot has wrenched it up tightly with an airgun. Do you not have a ratchet handle with an allen key socket? That makes the job so much easier.
    Runcorn
    Yer. Found that it aint an allen key but one of them strange star shaped inserts. Got right piece for it but still very tight .Think that they may have used an airgun on it.
    Yep, a Torx bit you mean. Again easier if you have the torx bits for a ratchet rather then just the allen key type ones.
    Runcorn
    yer torx bits. Thats the one. Got one on a ratchet but still really tight. Just imposs to move it......
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Bud
    give the drain plug a couple of sharp nocks with a hammer to shock the thread(as though you are nocking the plug up into the sump)then try again,you will be amazed how many idiots over tighten drain plugs causing this problem.
    if no luck put your torx on a socket bar pull on bar to remove plug and get someone to the tap the torx up to the sump wilst you keep pulling bar
    Just make sure it's a T45 sized torx bit. Some people think that it's a T40 then wonder why it slips and chews it up.
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    which is why my tool kit is a size 45 missing because it was done up soo tight it actually twisted the shaft of the bit!
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    if that fails a nice big pair of grips will free it lol
    Runcorn
    Tried the grips, but avin none of it. Will try again at the weekend.......Cheers guys
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
