Thread: Z22YH clutch how much
    Oct 2006
    southampton
    15 Post(s)
    Default Z22YH clutch how much
    Anyone got any ideas as to how much to fit new clutch and DMF, why do we need a new DMF and not just clutch plate, cheers in advance peoples...
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    What gearbox is fitted in yours? is it the F23 5-speed one?
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by danBoy View Post
    Tis indeedee Dan
    Regular Member DaveW555's Avatar
    Cannock
    Flywheel £465.11
    Clutch £223.24 (including slave cylinder)
    Flywheel Bolts £8.62 x6
    Gear Oil £15ish
    Brake Fluid £4ish
    Labour x4.7hrs
    Rough Guess but anywhere from £800 upwards, the flywheel on yours is the killer, dunno why its so dear on a 2.2 petrol when a 1.9cdti one is half that.
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by DaveW555 View Post
    Flywheel £465.11
    Gear Oil £15ish
    Brake Fluid £4ish
    Labour x4.7hrs
    Cheers Dave, why do you have to change the DMF when doing clutch, car has 18,000 on clock...
    Cannock
    You dont if its the clutch that has gone, you have to change the clutch if the dmf fails tho. 18000 miles for a clutch to fail is a bit poo tho I'd be having words with vx and see if they'll contribute towards it.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Z22yh Clutch
    By lizard in forum Engine & Drivetrain
    Last Post: 10th October 2012, 19:01
  3. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  4. Egr - z22yh
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 12:07
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
vauxhall z22yh clutch
