View Poll Results: what do i do
Voters
54. You may not vote on this poll
  • keep it and hope for the best
    33 61.11%
  • sell it
    3 5.56%
  • try the manifold
    5 9.26%
  • try the egr
    3 5.56%
  • thry 3rd injector
    3 5.56%
  • burn it
    10 18.52%
  • i have another idea ill post it for you
    3 5.56%
Multiple Choice Poll.
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: should i cut my losses
    Regular Member bunsen1's Avatar
    suffolk
    Exclamation should i cut my losses
    had vectra 2004/54 1.9 cdti sri 150 since 30 april this year costing me £4k + 82.50tax, extra insurance while selling the other car which is now £150
    upon buying the car i found i needed DMF so had the DMF clutch and slave fixed for £700
    upon registering on here i have now found out the bar is off the manifold, this will cost me around £375 to sort including the swirl motor
    3rd injector needs the mod £28
    plus i have the severe turbo lag under the 2k revs
    i really am not a man with money to throw at this car as i will not have any money to spare after doing all these, it will be all gone.
    want to try the manifold as i cleaned boost sensor and egr valve although the egr valve may need replacing £100
    adding all this up is costing me around 5.5k for a 4k car
    what would you do as i really liked the look of the car but if i dont find the turbo lag problem amongst all this then i will be well p****d off and have no money and no enjoyment
    serious replys only please
    Edinburgh
    I would say you've covered the majority of expensive things, you'll not see much of that money back if any if you sell it so if it was me I'd hang onto it.
    WGAF#5
    but now you have completed 99 precent of the work if you sell it ...your going to be even more out of pocket as you will not recoupe the money you have now outlayed
    stick with it mate - your almost there
    suffolk
    stick ya vote in for me my friend
    suffolk
    i have only done the DMF clutch and slave to date
    suffolk
    i forgot to mention it needs new brakes and and a tyre, and the dreaded mot is in oct
    use the poll to for me so i know where i am without having to keep reading back through to get the general census
    Should have bought a petrol, apart from a possible DMF they have far fewer faults. The extra you have paid would have kept the difference in MPG for ages depending on your milage.
    Edinburgh
    have a look around the forums there is some threads on cheap ways to fix the manifold bar. 3rd injector can be fixed for £12 if you own a soldering iron. EGR you might be able to clean it.
    Edinburgh
    You take a chance with any used car whether its petrol or diesel. Wouldn't imagine "you should have bought a petrol" is the most helpful advice he's gonna get.
    suffolk
    cleaned egr
    trying the fix at mo for manifold but he is going to take it out to have a good look and see how shot it is? engine is not very clean as i think it has been running for some time with the bar off
    can use a soldering iron so that changes that down to £12
    and yes big sig you aint half right are ya
  1. Transmission losses
    By Hideous in forum Diesel Engine related
    Last Post: 16th April 2011, 10:48
  2. More than 360 Luton Vauxhall job losses confirmed
    By Ollie in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 16:46
  3. Job Losses Close call
    By JSYSH466Y in forum General Chat
    Last Post: 25th February 2009, 19:59
