Results 1 to 3 of 3
Thread: Rear Brake Pipe
    Sep 2009
    Fife, Scotland
    Default Rear Brake Pipe
    Have a small leak in brake line running behind fuel tank.
    I have a 2.0 Dti Estate. On ramps or stands it is difficult to get access to see or feel whats going on. Really dont want to drop the tank.
    Can see pipe either side of tank in wheel areas. Is it possible to cut either end and then feed through a new copper section and join with flared fittings.
    Does anybody have a picture or diagram of underneath showing how the brake pipes run. Dont want to cut into pipe either end and find out i have a bit in middle under the tank going somewere.
    Note that this pipe runs up over a crossmember and along back of tank.
    Any help much appreciated.
    Jun 2006
    Kirkintilloch, Scotland
    Default Estate brake pipe replacement
    Had an MOT advisory note for these same brake pipes on my estate -the two that run from the front of the car to the back.
    Do you have to drop the tank for access or can can it be done another way?
    Thanks,
    Dave
    Jun 2006
    Default estate brake pipes
    Quote Originally Posted by Dancer View Post
    Hi Dancer,
    I know its a long time since your post but were you able to replace pipes without dropping the tank?
    Dave
  1. Brake pipe replacement
    By paulmatty in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2017, 14:50
  2. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  3. brake pipe help
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2012, 08:00
  4. vectra c brake/air pipe?
    By stuhack in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2012, 19:14
  5. brake pipe corroding
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 16:22
vectra c brake pipe diagram
vectra brake pipe diagram
https:www.vectra-c.comforumshowthread.php113084-Rear-Brake-Pipe
vauxhall brake pipe diagram
is there a break pipe above the diesel tank on a vauxhall vectra 2005
new rear brake pipe for vauxhall signum
vaxhull vectra c brake line diagram
vauxhall vectra c brake pipe routing diagram
easiest way to access brake pipe over fuel tank vauxhall vectra c
price for front and back brake pipes for vauxhall vectra sri estate car
diagram for rear vauxhall vectra brake pipe
vectra c break pipe leak
signum brake line.above.tank
vauxhall signum rear brake pipe replace
underneath vectra c brake pipes
vectra brake pipe diagram under fuel tank
how to replace back brake pips on vectra c
Vauxhall vectra C rear brake pipes
