Thread: brake wear sensor
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default brake wear sensor
    hi peeps!just wondering where abouts i can cut the wire and twist the wire just as im waiyting for a nnew sensor from ebay and the yellow light is annoyin on the dash!!do u just cut the sensor off then twist the bare wires around each other?heelppp!!
    Seperate them as joined they complete the circuit and put the light on.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    so what do people mean on here when they say cut the wires and join them?
    Regular Member garycole's Avatar
    Bedfordshire
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8
    you can always unplug the sensor and complete the circuit by using a piece of wire in the socket terminals this will put the light out until you get your replacement sensor
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    cheers
    Regular Member bigbnlr's Avatar
    Belfast
    mine are cut and taped together so yes it can be done
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    cheers!didnt work with the cut and tape but the circuit joined with a piece of wire has extinguished the light!
    Bedfordshire
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8
    good to hear u got sorted
  1. Brake wear sensor. Should my car have one?
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2013, 10:40
  2. Brake wear sensor put where?
    By kenp in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2012, 23:33
  3. Brake pad wear sensor
    By dittohead in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2010, 22:20
  4. Brake wear sensor
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 20:33
