Thread: LED day running lights
    Jun 2006
    teeside
    Default LED day running lights
    is it possible to swap the boring standard lights for the led,s or is it only possible if you have the full xenon headlight setup?
    Leicester
    There is a possibility that the Xenon ALF lights could be fitted and programmed. But the AFL functions won't work.
    I am looking into this.
    Mar 2007
    North East
    The DRL's on the halogen lights are dual element bulbs. It may be possible to replace with led's but then there's the issue of fooling the bulb failure monitor.
    Sure I've seen a post on one of the insignia forums, will have a look.
    Jun 2006
    teeside
    i was hoping to replace just the day lights not the whole thing as i could imagine that getting quite expensive
    Mar 2007
    North East
    The bulb for the DRL's is a twin element so is DRL and side light. A few people have replaced them with Piaa bulbs but they have a higher wattage and there have been reports of them damaging the light housing.
    North East
    I bought a pair of 21w/5w LED bulbs and plugged them in. The running lamps which are the 21w part of the bulb looked excellent, bright white light and very bright. I then turned my lights on and the 5w part of the bulbs 'should' have lit and the 21w went out. All it did was started to smoke so I had to pull the bulb out.
    The terminals on the bulbs are exactly the same as the original bulbs so the 21w and the 5w parts should have worked. It appears that only the 21w part was working. I have not had another look to see what the problem could be yet.
    It did show a bulb out warning on the dash though.
  1. Day running lights will they fit??
    By BooDaChris in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 11:44
  2. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  3. led running lights
    By triple595 in forum Styling
    Last Post: 21st April 2011, 14:01
  4. running lights
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 08:26
  5. day running lights? any easy fit ones
    By veralum in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2010, 18:09
