Thread: Rear leccy window conversion
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Angry Rear leccy window conversion
    hi guys, been reading the how to and gonna need to have a go with this as my new door cards are for eccy rear windows,
    if i say that i'm a complete moron when fitting anything like this - would you still attempt it or.....
    thanks in advance Andy
    Wales, UK
    You should definately have a go! Hopefully you have all the wiring, etc in place so it should be plug n play, all be it tech 2...
    Regular Member Bethan39's Avatar
    South Wales
    I've just finished doing this to mine! have you checked if you have the wiring in place? as in undo the blue plug connection between your car door and the one on the body if the one on the body has two pins then dead easy if both sides has only one like mine did then it get a lot harder if you need any help or questions feel free to ask hth
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Planning to attempt this later in the year, no funds as of yet... Have a go.
    South Wales
    Quote Originally Posted by leemarksmith View Post
    have you checked yours yet like i said if you have both pins on the car side no problem! worth checking first let us know
    Jun 2009
    bradford
    Thumbs up
    thanks guys, yea i have the wires................will it defo need tech2ing?.....gulp will have to have a go.................lol
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    You'll need to tech2 it first otherwise once you fit it all your back windows will most likely be open and you won't be able to close them.......
    Jun 2009
    bradford
    Quote Originally Posted by danBoy View Post
    .............never thought of that!!...........been reading that they don't always need activating, or is that bs?.........thanks again
    Jun 2006
    Northampton
    Quote Originally Posted by hairy31 View Post
    It can be hit and miss as to whether it will be activated or not, but only one way to find out lol.........
  1. rear window conversion
    By jon1.9cdti in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2012, 18:46
  2. Rear Electric Window Conversion
    By IWC in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2010, 13:28
  3. rear electric window conversion
    By keith150882 in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2010, 22:46
  4. rear leccy window problem
    By GSi-Col in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2009, 20:01
  5. Rear Window Conversion
    By sbfos in forum Bodywork & Interior
    Last Post: 2nd January 2007, 14:06
