Thread: parking sensors
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default parking sensors
    hi all i fitted some aftermarket parking sensors the other week and have noticed that when i put it in reverse it keeps beeping when im not near anything but when i put the brakes on it stops??? and also today ive noticed that if the lights are turned off it doesnt do it so turned the lights on and it started beeping very confused have i wired it to the wrong wire? the senors still work if i get close to anything but the continuous beeping is driving me insane!!
    Feb 2007
    anyone??
    Regular Member Bethan39's Avatar
    South Wales
    Did you connect one wire to earth then the other to the reversing light wire?
    Full Member Big Sig's Avatar
    Quote Originally Posted by Bethan39 View Post
    Thats sounds like SOUND advice
    Did you connect it to the correct live?
    Regular Member connery-sri's Avatar
    Basildon, Essex
    Mine only turns on when reverse gear is engaged.
    Powered by reverse lights.
    Regular Member Innes's Avatar
    Plymouth
    Sounds like you wired it into the wrong wire chap.
    Feb 2007
    the live is connected to the number 2 wire is this right? i was told it was the black/white one but there is more than one? they still work correctly but its the beep beep beep!!! that comes on even when you are nowhere near anything when the headlights are on then if i press the brake pedal it doesnt do it? otherwise they are fine here is a pic could someone tell me if i have connected it to the right one?? tia
  1. OE Parking sensors
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2012, 19:02
  2. parking sensors
    By happypostie in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2009, 02:04
  3. HELP parking sensors
    By lee11 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2009, 13:38
  4. Parking Sensors! Help!
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 23:52
  5. Parking Sensors
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 21:58
