Results 1 to 10 of 15
Thread: more smoke
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Unhappy more smoke
    well yesterday thought we were going to solve prob with smoking(burning oil) on the Z20NET so new air filter,oil filter, fuel filter,ngk spark plugs, mobil 1 oil, the o2 sensor, was changing the exhaust temp sensor but for some reason the new one is twice as long as old one so was a bit unsure so did not fit but going to change it today.
    so changed all this and now it;s idling fine but now even more smoke than before even when accelerating.
    im realy confused and so was my mechanic mate.
    phone vx and a saab place e.c.t and each one said they have never had such a prob with theese engines.
    so could it be the only part thats not been fitted yet thats causing oil to burn through exhaust ?
    also why would it start within a week of having a new ss exhaust fitted
    so heres a vid b4 it started smoking like within a week
    http://www.youtube.com/watch?v=WTLDX...eature=related
    heres a vid of before parts got fitted
    http://www.youtube.com/watch?v=0wgYEnYNADk
    and how it is now
    http://www.youtube.com/watch?v=ssi4JPLAEAs
    Hmm, that is a fair bit of smoke! Definitely not right.
    So this only started after having a new exhaust fitted? What sort of system? i.e. full system inc cat?, or was it from the original cat back?
    White/grey smoke on a turbo car is often turbo related e.g. seals on turbo gone allowing oil into turbo. Can also be other oil seals in the engine itself.
    If you can give a bit more info about what system has been installed i.e. whether original cat is still there or whether they removed that and fitted a new downpipe (with sports cat) directly onto the turbo then that may help narrow it down.
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    had a 3" cat back cobra sport system fitted, still got original cat on it.
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    also just been on net looking at differant things that would make it smoke and came accross that a faulty pcv valve can make smoke, anyone got an idea were it is.
    I agree with dincan, the most likely cause is a ****ed turbo imo. Have you removed the pipes from the turbo to see if they are full of oil? Some is fairly normal, but lots would be a sign of the oil seals.
    I agree with dincan, ..
    Dincan? Have we turned into Inspector Clouseau with ze minkees?
    Oooops
    Sorry
    Regular Member booker413's Avatar
    West sussex
    looks like your turbo mate, how many miles have you done, it looks like the oil inlet valve for the turbo. you can get the turbo serviced, if not there is a new one on flea bay for .......................£350 . best of luck mate
    adam
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    milage is at 85000 miles, £350 thats cheap cheers, i suppose a turbo's better than somthing internal but would rather it be somthing little.
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    also i forgot so add that the oil iv'e put in is mobile1 0w 40 if that make a differance
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. How much smoke?
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 11th April 2012, 21:25
  3. smoke
    By ryanhamil in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 11:19
  4. smoke
    By scoobyman in forum Diesel Engine related
    Last Post: 22nd August 2008, 10:51
  5. Smoke
    By JCB in forum Parts for sale
    Last Post: 21st September 2005, 13:35
