Thread: Creaking brakes 2.2DTI SRi..?
    Regular Member bigdave1701's Avatar
    York
    Default Creaking brakes 2.2DTI SRi..?
    Ive done a search but couldn't find anything so.....
    When braking at low speeds (10mph-0mph) I get a creaking noise. From just listening to the noise whilst driving, I've been unable to tell if its coming from the front or rear of the car. However, I investigated slightly last night and whilst theres no play in the front wheels, when holding a rear wheel at 12 o'clock and giving a sharp tug, there is a noticeable amount of play and a clunking noise.
    Is it likely that the creaking is related to this play? Can anyone point me in the direction of what the problem may be?
    Dave
    Regular Member Jezzy's Avatar
    S.E
    Your rear upper control arms need to be replaced - they're the banana shaped metal bars with a rubber bush at each end.
    York
    Thanks. Is it a hard job to do? Im intending changing the discs and pads very soon so could do perhaps do it at the same time?
    S.E
    Quote Originally Posted by bigdave1701 View Post
    Not a bad idea to do these jobs at the same time, especially as Haynes recommends unbolting the brake caliper before changing the control arms, to give you more room - although I left the caliper where it is. The best job to combine with the control arms though is replacement of the rear springs. Access to the inner bolt is a lot harder with the spring in place -can anyone comfirm they've changed the control arms without removing the springs?
  1. brakes creaking
    By james walker in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2012, 00:06
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. creaking
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 25th August 2011, 08:13
  4. Creaking sound from Brakes
    By mikaz in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2009, 14:40
  5. Not as much bite in my gsi brakes as in 2.2dti elite...
    By RobDMX in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2008, 21:22
vectra c brake piston creaking
brakes creaking vauxhall
