Thread: cost of replacing tyres
    Default cost of replacing tyres
    had a look round the siggy yesterday and noticed that the fromnt tyres are getting quite low , now i know there still legal but they will need replacing soon and i have the mot coming up in the next month
    so i looked on the t'internet and priced up new tyres
    at the moment it has eagle nct 5 all round so obviously i looked at the price of these
    now i know £120 ish for decent tyres isnt bad but it actually works out cheaper for me to buy a new set of alloys ( ie bk999's ) with tyres than it is to just replace all the tyres
    now whats the logic in that !!!!!!!
    Mar 2007
    Beaconsfield, Bucks
    The tyres you get on the bk999s will only be about £50/60 each. I bought some BK999s a couple of years ago and they had Nankang NS2s on them which were actually OK, but a bit crap in the wet, definitely a budget tyre. Theyre not a patch on most decent premium tyre brands (ie Goodyear) .I also noticed they were as hard as nails, a really stiff sidewall, the tyres I have on now improve the ride massively.
    If you do go ahead then I wouldnt buy NCT5s they are previous generation tyres, get something newer like Goodyear F1 Assymetrics for roughly the same price.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The Kumho KU31's are well respected on this forum too, and are a decent price too
    WGAF#5
    as above -when buying a set of alloys unless you "upgrade" you will get budget rubber which means you will end up replacing fairly quickly so not as economical as you thought
    8 Post(s)
    Quote Originally Posted by marktaylor View Post
    Do yourself a favour and don't replace with more NCT5's.
    Once you replace them with another make of tyre, you'll realise how bad the NCT5's were.
    I can recommend Uniroyal Rainsport2's. Bags of grip, run a lot quieter than the NCT5, and the wear rate isn't too bad either. 9,000 miles on the front tyres and still had approx 5mm of tread left, before putting them on the rear - I'm not the slowest of drivers either. If you shop round you should be able to pick them up for around £80 a corner (not fitted, size 225/45/17). If you've currently got 215/50/17's then changing to the other size (225/45/17) will save you money as they're a more common size than the 215/50's.
    Full Member Big Sig's Avatar
    Try places like camskill for cheap tyres. Those ntc5's are of unknown age
    May 2007
    GLASGOW
    I found nankang pretty good. I would never pay full frice for a standard size tyre, i would go partworn for about 20quid a corner, u can get some good partworns if u look around
    Part worn tyres for £20
    Well you pays your money and you take your chances...
    I use only "premium" tyres, £100 per tyre fitted
    Swapped from the Good Year 215/50R17 to 225/45R17 simply as the "original" tyres are £150 each
    Regular Member DaveW555's Avatar
    Cannock
    I've just had the Uniroyal Rainsport 2's on mine and I have to agree with BigDave 100%, they are far better than tyres three times the price, If you want to save some pennies look out for some Nexen's, they're a budget brand but they're better than Goodyear Eagle F1's (I had both on my beemer), last longer and better grip I found.
    8 Post(s)
    Quote Originally Posted by LEW1S2006 View Post
    Do you get told of the history of the tyre(s) or just take a chance they're not from a written off car?
  1. Cost of replacing
    By johnny kebab in forum Engine & Drivetrain
    Last Post: 2nd December 2012, 16:18
  2. cost of replacing injector seals ?
    By Rocky Balboa in forum Engine & Drivetrain
    Last Post: 20th January 2012, 21:36
  3. Cost of replacing a consumer unit
    By peelmeister in forum The 'Off Topic' room
    Last Post: 12th May 2011, 16:04
  4. Cost of replacing entire auto dimming door mirror?
    By Elite Estate in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2008, 21:04
  5. Replacing tyres
    By cabbage in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2008, 17:41
