Thread: how do u
    Regular Member Dan.'s Avatar
    milton keynes
    Default how do u
    take the wing mirror covers off someone know? thanks
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    You simply prise the cover off from the inside edge all the way round where it meets/clips onto the black edging of the mirror housing. Hope that makes sense.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    easy way is to pop out the mirror glass carefully then squeeze the 4 sets of back cover clips together that are located behind the glass.
    WGAF#5
    no you dont!!
    remove the mirror glass. inside there are 4 x retaining lugs these need to be popped out ( when you look into the mirror housing having removed the glasss you should see theses)you should and then there is a small indent pin on the top inside edge of the mirror capping - then you can slowly work your way around the mirror capping till it comes away - take your time and you will be fine
    this comment was in response to John K sri's (not Bobby's as he posted whilst i was typing!!)
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    no you dont!!
    phewwwwwww!! pmsl i did try john's method once and managed to get the back off but also smashed all the retaining clips from the mirror back.
    Edinburgh
    Quote Originally Posted by bobby-tupper View Post
    milton keynes
    cheers lads much appreciated does the glass come off easy?
    [Ex]Admin Duncan's Avatar
    Yep, just swivel the glass from the door control until it's pointing as far in towards the car as it can. Then get something like a flat plastic spatula and put it as far behind the glass as you can through the space that is now there. Gently prise it forwards until the glass pops off.
