Thread: Couple of quick air-con condenser questions
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Default Couple of quick air-con condenser questions
    Evening Gents,
    Just bought a new condenser from autoairconparts and it said this on the receipt :
    Warranty: All condensers now come with 18 months warranty from date of order, all other parts supplied come with a 12 month warranty. Compressor warranty subject to receiver drier, expansion valve and system flush, failure to do so may invalidate warranty.
    YOU MUST CHECK OIL LEVEL IN COMPRESSORS BEFORE INSTALLATION, FAILURE TO DO SO WILL INVALIDATE WARRANTY. COMPRESSORS SUPPLIED DO NOT ALWAYS HAVE CORRECT OIL CHARGE SO IT IS THE INSTALLERS RESPONSIBILITY TO CHECK.
    I thought of just fitting it and taking it to garage to have it re-gassed with gas, oil and dye. Would this be ok ?
    2nd Q. What do people undo to get that psst sound when taking the condenser off ? is it by undoing the two 13mm bolts on the side ?
    Cost for the condenser ( which is OEM ) was £104 incl vat AND delivery for a 1.8 vvti engine (next day del ). Just have to buy 'O' rings from Vauxhall now. If anyone knows the part nos. it would be appreciated.
    Thanks once again in advance
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    It's www.autoairconparts.co.uk and they are saying they are brand new OEM if anyone is interested, should be here tomorrow and will do a how2
    Regular Member brigrif's Avatar
    South Shields
    I know you said you need it re gassed but make sure nobody catches you letting air con gas off into the atmosphere as it's illegal. The psst sound to check if any gas is in the system is on the high pressure port of the air con system. Again it should be done with a regulator to check for pressure reading. Normal levels are around 4-5 bar of pressure in a sound system, any lower than that then you either need a top up or you have a leak somewhere. also, make sure you wear good eye and body protection when undoing the system if gas/refridgerant is still present cos it gives nasty frostbite.
    PS You will still get the psst sound when undoing the connections from the condenser aswell.
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Part numbers for o rings anyone ? 1.8 petrol
    South Shields
    Quote Originally Posted by siadwel View Post
    If you go to andrew page , that's where I used to get all my o rings from for work for all types of vehicles , they will definately stock them.
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Thanks, but none near me and it's £7 p&p
  1. couple questions
    Last Post: 19th November 2011, 23:16
  2. Couple of quick 'where' questions
    By Giddy in forum Engine & Drivetrain
    Last Post: 16th September 2011, 22:26
  3. Couple of questions
    By Pete1nlancs in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2010, 20:14
  4. couple of questions
    By kev bux in forum Engine & Drivetrain
    Last Post: 5th February 2009, 19:52
  5. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
