Results 1 to 10 of 13
Thread: Car not starting!!!
    aberdeen
    Default Car not starting!!!
    Hey guys, gotta problem. Gotta 55plate 1.9 cdti 120. Problem is when i go out to start the car in the mornings for work it takes ages to actually start when im turning the key, and when it does eventually start a big cloud of black smoke comes from the exhaust. It happens when im away to come home from work aswell.
    Any ideas??
    Is it cos the engine is cold and could be something to do with that??
    Please help, its getting very annoying!!
    Thanks!!
    Regular Member DaveW555's Avatar
    Cannock
    Do you let the glow plug light go out?? If so its a long shot but I've not heard of any yet so you could be the first with leak off pipes gone on a CDTi.
    Worcs/Staffs/Westmids (ish)
    Has the car been serviced regularly and correctly?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Is there any lights in dash to indicate a fault
    Irmscher Insignia CDTI 130
    Jan 2010
    glasgow
    id go for the glow plugs or pos the leak off pipes have u tried giving it 2 or 3 pre heats before u try and start it?
    aberdeen
    Glow plugs were replaced less than 6 months ago and has had a full service about the same time. No warning lights either and yes i do wait for the lights to go out and also try a couple of times but......
    Had it to an auto electrician today and they got the injectors leak tested and they all came back fine, so they ran all the diagnostics on my car and it came back with no fault codes on my car so the guy suggested getting all my throttle housing and egr cleaned out properly. He said it was just a suggestion so do u guys think this could affect it in any way??
    Thanks!!
    Quote Originally Posted by bry607 View Post
    Well if it was done at a stealership you might find all they actually did was stamp the logbook... :/
    aberdeen
    Went to vauxhall today and they think that it could maybe be the injector seals.
    What do u think???
    Cannock
    for the sake of a couple of quid for the set it cant hurt to chuck some in it
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Worth a try I guess, also is it possible that EGR could cause a bad start?
    Last edited by plasma; 17th June 2010 at 18:50. Reason: thought it was the dreaded dti!
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Not Starting
    By mungo1985 in forum Engine & Drivetrain
    Last Post: 11th September 2012, 21:52
  2. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  3. bad starting
    By reg in forum Engine & Drivetrain
    Last Post: 20th April 2011, 09:01
  4. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
