Thread: modification to air box????
    Regular Member mbonnick's Avatar
    Jul 2006
    letchworth, hertfordshire
    Default modification to air box????
    In a different post Spikey hinted that there is a modification you can do in the air box which involves removing the half pipe.
    Will it cause me any problems if I do this and if not then what purpose does it serve in there if it can be taken out, my tiny brain cant get past the reasoning behind Vauxhall putting it in if its not needed. Will doing the above make a noticeable difference ie any gain in BHP, i imagine not but if it can breath better then I can see the benefit to doing it.
    Feb 2006
    Dorset
    Im going to stick mine back in as like on a kawasaki it sems to ram air into the corner of the box where on the opposite side of of the filter the pick up is , the ammount of **** the vauxhalls pick up is amazing , ive found a fag butt bird wing and a **** load of flies along with the normal debris in my airbox !
    SOMERSET
    Quote Originally Posted by DennisTheMenace
    That's why you have a air filter, it's need to be checked often.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The funnel shaped thing in the lid causes the air to slow down and thus the pressure to increase. That way you get better transferance of air through the filter and a more even transfer over the whole filter.
    I modified my box to add an extra cold air feed but the ECU used to complain about the amount of air going in with the little car and spanner (at about 4000rpm onwards). Having been discusted with the amount of **** I've found in my air box too I decided to put filters over the air intakes to stop large particles even getting to the filter. I now still have plenty of air getting in but it is much cleaner.
    there is also another reason why VX had to install the baffle pipe,
    it was for noise polution regulations, the baffle pipe reduced the decibles of the air intake system and as such made it quieter ,
    taking out the pipe makes the induction noise a little louder and gives the car a slightly better ' burble ' , while giving a little more airflow allowing for better combustion
    BB
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I didn't notice a change in noise when I took mine out? Might have been after I added the extra air feed to the box though...
    maybe you had ur boom-box up too loud, lol
    BB
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Makes a very nice woosh noise with the extra feed, wouldn't dream of drowning that out, I love listening to it as I change gear and it whistles down then up again.
    North east HQ
    ive not noticed any of these problems since removing mine, although it does seem to run a bit smoother
  1. air box modification
    By davedave in forum Petrol Engine related
    Last Post: 10th May 2012, 23:13
  2. Need Help in modification
    By my834 in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2010, 01:27
  3. New modification..........
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2008, 15:37
  4. 1st Modification
    By Gregg in forum Quick Photo Album
    Last Post: 15th November 2007, 16:51
  5. Next modification anyone??
    By j13hdb in forum Comedy & Humour
    Last Post: 13th November 2007, 16:15
vectra c air intake pipe baffle
