Thread: Bumper re-painting prep advice please
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default Bumper re-painting prep advice please
    Iv got An SRI bumper i need to get painted as its the wrong colour off an 07 reg car .... .... iv got a bottom lip spoiler to glue on too and iv got the tiger seal...
    But ... should i scratch down the old paint with 600 grit wet & dry 1st ?
    Also, if some1 could let me know how these side skirts fit too ?? ... iv got some plastic clips/straps ... but iv never fitted them B4
    All help is much appreciated
    Thank you
    Regular Member Jezzy's Avatar
    S.E
    You do indeed need to rough up/key the surface of the bumper before repainting it, or the new paint will struggle to stick to it. 600 grit seems a bit coarse though, maybe try a finer grade.
    shropshire
    OK, thanks
    Regular Member AKeeNShoT's Avatar
    South Shields, T&W
    hi mate, key it with scotch pad. where you going to be sparaying it? oven? shed? garden? with regards to the last 2 you should really flatten between coats also, using 1600-2000 grit w/d, with plenty of water, same with the clear coat.
    hth,
    michael
    shropshire
    Quote Originally Posted by AKeeNShoT View Post
    hth,
    michael
    Im getting a spay/repair centre to paint it ... but thought id save a bit by prepping it myself
    so id 600grit a def' No No ? as iv got some spare
    Regular Member *enery*'s Avatar
    Mar 2007
    glasgow
    6OOgrit will be fine bud,solvent base coat can cover 400grit scratches,and water base basecoat can cover 600grit scrathes.only time i use lighter paper would be for a light colour.
    shropshire
    Quote Originally Posted by *enery* View Post
    Thanks Bud
  1. Advice on prep for painting
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2012, 08:57
  2. House Painting & Decorating - Corner/Edge Painting advice
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 14th January 2011, 17:45
  3. Replies: 3
    Last Post: 16th July 2010, 01:05
  4. Bumper Painting Advice
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2009, 18:31
  5. Painting Advice
    By Damian in forum Styling
    Last Post: 30th July 2007, 22:38
