Thread: Brakes
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Brakes
    Hi All,
    Im looking to change my brakes, can i get 302's as i have 285s at the minute. 55 reg Vectra 1.9 SX CDTI.
    Steve
    As I found some for £40.19 inc vat should have been £170.20
    http://www.carpartsconnexion.com/vau...y=2005&cat=19&
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes you can.
    But i wouldnt believe anything on that web site, they always post cheap prices and when you ring up that price never exists.
    Their has been alot of people on here moaning about that web site.
    Thumbs up
    Ok m8 thanks for the info and heads up
    Regular Member DaveW555's Avatar
    Cannock
    You can't just change the discs and pads, you'll need the callipers to go with them and as Graham has said, if it sounds too good to be true, it probably is.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by vectra 120 View Post
    Hi All,
    Steve
    Yeah you can fit any size brakes that you want to on the Vec but you will need discs callipers and carriers for moving to 302s (the pads are the same if yours are good)
    I have 302s fitted to my 2.2dti which originally had 285s
    Full Member Penfold101's Avatar
    I've had good experiences with that site - yes you need to ring up and find out if the parts are still available, but I got a set of 292mm discs and pads for 45 squid...
    Thanks all
    I only have 16 inch alloy wheels will the 302 callipers fit?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yes, there was a member on here who had the 314s on his car fitted with 16's so the 302s shouldn't cause an issue
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
